Datasheet Texas Instruments OPA658P — Даташит
СерияOPA658
МодельOPA658P
Широкополосный операционный усилитель с обратной связью по току малой мощности 8-PDIP
Package TypeP
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Width (мм)6.35
Length (мм)9.81
Thickness (мм)3.9
Pitch (мм)2.54
Max Height (мм)5.08
Рекомендуемая замена
ReplacementOPA694ID
Replacement CodeP
RoHSНе совместим
  • Evaluation Modules & Boards: DEM-OPA68XP
    DEM-OPA68xP: Demonstration Fixture
  • The Current-Feedback Op Amp: A High-Speed Building Block
    PDF, 117 Кб, Файл опубликован: 2 окт 2000
    Although current-feedback amplifiers (CFAs) have been in use for quite some time, there is a reluctance to view them in the same light as voltage-feedback amplifiers (VFAs). For instance, the gain-bandwidth curve of VFAs has a parallel in a transimpedance-bandwidth curve for CFAs. This parameter can be used to determine the closed-loop behavior of the CFA in same way that GBW can for the VFA. Not
На английском языке: Datasheet Texas Instruments OPA658P
