Datasheet Texas Instruments OPA699ID — Даташит
СерияOPA699
МодельOPA699ID
OPA699: Широкополосный усилитель-ограничитель напряжения с высоким коэффициентом усиления 8-SOIC от -40 до 85
Wideband, High Gain Voltage Limiting Amplifier datasheet
PDF, 1.0 Мб, Версия: D, Файл опубликован: 30 дек 2008
Pin88
Package TypeDD
Industry STD TermSOICSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY7575
CarrierTUBETUBE
МаркировкаOPA699
Width (мм)3.913.91
Length (мм)4.94.9
Thickness (мм)1.581.58
Pitch (мм)1.271.27
Max Height (мм)1.751.75
2nd Harmonic67 dBc
3rd Harmonic87 dBc
@ MHz5
Acl, min spec gain4 V/V
Additional FeaturesN/A
АрхитектураVoltage FB
BW @ Acl260 МГц
CMRR(Min)55 дБ
CMRR(Typ)61 дБ
GBW(Typ)1000 МГц
Input Bias Current(Max)10000000 pA
Iq per channel(Max)15.9 мА
Iq per channel(Typ)15.5 мА
Количество каналов1
Offset Drift(Typ)15 uV/C
Output Current(Typ)120 мА
Rail-to-RailNo
Slew Rate(Typ)1400 V/us
Total Supply Voltage(Max)12 +5V=5, +/-5V=10
Total Supply Voltage(Min)5 +5V=5, +/-5V=10
Vn at 1kHz(Typ)13 нВ/rtГц
Vn at Flatband(Typ)4.1 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)5 мВ
  • Evaluation Modules & Boards: DEM-OPA-SO-1A
    DEM-OPA-SO-1A Unpopulated PCB Compatible w/High Speed Wide Bandwidth Op Amps in 8-lead SOIC (D) Pkg
  • RLC Filter Design for ADC Interface Applications (Rev. A)
    PDF, 299 Кб, Версия: A, Файл опубликован: 13 май 2015
    As high performance Analog-to-Digital Converters (ADCs) continue to improve in their performance, the last stage interface from the final amplifier into the converter inputs becomes a critical element in the system design if the full converter dynamic range is desired. This application note describes the performance and design equations for a simple passive 2nd-order filter used successfully in AD
  • ADS5500, OPA695: PC Board Layout for Low Distortion High-Speed ADC Drivers
    PDF, 273 Кб, Файл опубликован: 22 апр 2004
    Once an analog-to-digital converter (ADC) and a driver/interface have been selected for a given application, the next step to achieving excellent performance is laying out the printed circuit board (PCB) that will support the application. This application report describes several techniques for optimizing a high-speed, 14-bit performance, differential driver PCB layout using a wideband operation
  • Measuring Board Parasitics in High-Speed Analog Design
    PDF, 134 Кб, Файл опубликован: 7 июл 2003
    Successful circuit designs using high-speed amplifiers can depend upon understanding and identifying parasitic PCB components. Simulating a design while including PCB parasitics can protect against unpleasant production surprises. This application report discusses an easy method for measuring parasitic components in a prototype or final PC board design by using a standard oscilloscope and low freq
Серия: OPA699 (3)
На английском языке: Datasheet Texas Instruments OPA699ID
