Datasheet Texas Instruments TPS650732RSLR — Даташит
СерияTPS650732
МодельTPS650732RSLR
5-канальная ИС управления питанием (PMIC) с 3 DC/DC, 2 LDO в корпусе QFN 6x6 мм 48-VQFN от -40 до 85
TPS65070x Single Chip Power Solution for Battery Powered Systems datasheet
PDF, 2.1 Мб, Версия: H, Файл опубликован: 30 сен 2015
Pin4848
Package TypeRSLRSL
Industry STD TermVQFNVQFN
JEDEC CodeS-PQFP-NS-PQFP-N
Package QTY25002500
CarrierLARGE T&RLARGE T&R
МаркировкаTPS650732
Width (мм)66
Length (мм)66
Thickness (мм).9.9
Pitch (мм).4.4
Max Height (мм)11
Iout(Max)1.5 A
Iq(Typ)0.08 мА
LDO2
Package GroupVQFN
Package Size: mm2:W x L48VQFN: 36 mm2: 6 x 6(VQFN) PKG
Processor NameAM3505/17
Processor SupplierTexas Instruments
Regulated Outputs6
Shutdown Current(Typ)0.08 uA
Special FeaturesComm Control,Power Good,Power Sequencing
Step-Down DC/DC Converter3
Switching Frequency(Max)2250 kHz
Vin(Max)39 В
Vin(Min)1.8 В
Vout(Max)19.2 В
Vout(Min)0.725 В
  • Evaluation Modules & Boards: TPS650732EVM-430
    Evaluation Module for TPS650732 5-Channel Power Management IC
  • TPS6507x Device Comparison
    PDF, 54 Кб, Файл опубликован: 19 фев 2010
    This application report presents an overview of the differences among the TPS65070,TPS65072, TPS65073, TPS650731, and TPS650732 power management integrated circuits (IC). It can assist design engineers in selecting the most suitable IC for their applications.
  • How to Power the TPS6507x On and Off
    PDF, 169 Кб, Файл опубликован: 12 апр 2012
  • AM3517/05 Pwr Ref Design 3.6V to 6.3-V Input, Hi-Effic, Integratd 5-Output PMIC
    PDF, 84 Кб, Файл опубликован: 8 апр 2010
    This design was created to help those designers desiring an optimized and highly integrated power management solution for the AM3517 and AM3505 processors. Using a power management integrated circuit (PMIC) to power your processor can greatly reduce the number of components and overall size of your design.
  • Dynamic Power-Path Mgmt & Dynamic Power Mgmt
    PDF, 96 Кб, Файл опубликован: 2 янв 2007
    Dynamic power-path management (DPPM) and dynamic power management (DPM) are two similar types of integrated power management ICs that combine the task of charging a single-cell Li-ion battery and powering the system. Both topologies reduce the battery charging current to give the system priority when the adaptor has reached its output current rating. The bq2403x family and TPS65800 IC use the DPP
  • Understanding the Absolute Maximum Ratings of the SW Node (Rev. A)
    PDF, 755 Кб, Версия: A, Файл опубликован: 13 янв 2012
Серия: TPS650732 (2)
  • Semiconductors > Power Management > Power Management Multi-Channel IC (PMIC) Solutions
На английском языке: Datasheet Texas Instruments TPS650732RSLR
