Datasheet Texas Instruments TPS65073RSLR — Даташит
Серия | TPS65073 |
Модель | TPS65073RSLR |
5-канальная ИС управления питанием (PMIC) с 3 DC/DC, 2 LDO в корпусе QFN 6x6 мм 48-VQFN от -40 до 85
TPS65070x Single Chip Power Solution for Battery Powered Systems datasheet
PDF, 2.1 Мб, Версия: H, Файл опубликован: 30 сен 2015
Pin | 48 | 48 |
Package Type | RSL | RSL |
Industry STD Term | VQFN | VQFN |
JEDEC Code | S-PQFP-N | S-PQFP-N |
Package QTY | 2500 | 2500 |
Carrier | LARGE T&R | LARGE T&R |
Маркировка | 65073 | TPS |
Width (мм) | 6 | 6 |
Length (мм) | 6 | 6 |
Thickness (мм) | .9 | .9 |
Pitch (мм) | .4 | .4 |
Max Height (мм) | 1 | 1 |
Iout(Max) | 1.5 A |
Iq(Typ) | 0.08 мА |
LDO | 2 |
Package Group | VQFN |
Package Size: mm2:W x L | 48VQFN: 36 mm2: 6 x 6(VQFN) PKG |
Processor Name | OMAP35xx |
Processor Supplier | Texas Instruments |
Rating | Catalog |
Regulated Outputs | 6 |
Shutdown Current(Typ) | 0.08 uA |
Special Features | Comm Control,Power Good,Power Sequencing |
Step-Down DC/DC Converter | 3 |
Switching Frequency(Max) | 2250 kHz |
Vin(Max) | 39 В |
Vin(Min) | 1.8 В |
Vout(Max) | 19.2 В |
Vout(Min) | 0.725 В |
- Evaluation Modules & Boards: TPS65073EVM-430
Evaluation Module for TPS65073 5-Channel Power Management IC
- TPS6507x Device ComparisonPDF, 54 Кб, Файл опубликован: 19 фев 2010
This application report presents an overview of the differences among the TPS65070,TPS65072, TPS65073, TPS650731, and TPS650732 power management integrated circuits (IC). It can assist design engineers in selecting the most suitable IC for their applications. - How to Power the TPS6507x On and OffPDF, 169 Кб, Файл опубликован: 12 апр 2012
- Dynamic Power-Path Mgmt & Dynamic Power MgmtPDF, 96 Кб, Файл опубликован: 2 янв 2007
Dynamic power-path management (DPPM) and dynamic power management (DPM) are two similar types of integrated power management ICs that combine the task of charging a single-cell Li-ion battery and powering the system. Both topologies reduce the battery charging current to give the system priority when the adaptor has reached its output current rating. The bq2403x family and TPS65800 IC use the DPP - Basic Calculation of a Boost Converter's Power Stage (Rev. C)PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed. - Understanding the Absolute Maximum Ratings of the SW Node (Rev. A)PDF, 755 Кб, Версия: A, Файл опубликован: 13 янв 2012
- Basic Calculation of a Buck Converter's Power Stage (Rev. B)PDF, 202 Кб, Версия: B, Файл опубликован: 17 авг 2015
- Choosing an Appropriate Pull-up/Pull-down Resistor for Open Drain OutputsPDF, 130 Кб, Файл опубликован: 19 сен 2011
Серия: TPS65073 (2)
- TPS65073RSLR TPS65073RSLT
- Semiconductors > Power Management > Power Management Multi-Channel IC (PMIC) Solutions
