Линейка продуктов KEEN SIDE
Datasheet Texas Instruments TPS65086470RSKT — Даташит
СерияTPS650864
МодельTPS65086470RSKT
Конфигурируемый многоканальный PMIC для Xilinx MPSoC и FPGA 64-VQFN -40 до 85
TPS650864xx Configurable Multirail PMU for Xilinx MPSoCs and FPGAs datasheet
PDF, 1.8 Мб, Файл опубликован: 15 фев 2017
Pin6464
Package TypeRSKRSK
Industry STD TermVQFNVQFN
JEDEC CodeS-PQFP-NS-PQFP-N
Package QTY250250
CarrierSMALL T&RSMALL T&R
МаркировкаPG1.0T65086470
Width (мм)88
Length (мм)88
Thickness (мм).85.85
Pitch (мм).4.4
Max Height (мм)11
Iout(Max)21 A
LDO4
Package GroupVQFN
Package Size: mm2:W x L64VQFN: 64 mm2: 8 x 8(VQFN) PKG
Processor NameArtix 7
Processor SupplierXilinx
Regulated Outputs12
Step-Down DC/DC Controller3
Step-Down DC/DC Converter3
Vin(Max)21 В
Vin(Min)5.4 В
Vout(Max)3.575 В
  • Evaluation Modules & Boards: TPS650860EVM-116
    TPS650860 Evaluation Module
  • Push-Button Circuit (Rev. A)
    PDF, 188 Кб, Версия: A, Файл опубликован: 11 июл 2017
    This application report details a push-button circuit that can be used in tandem with a power management integrated circuit (PMIC) to turn on and turn off the processor. The SN74LVC1G175 device is a D-type flip-flop with an asynchronous clear. The circuit differentiates between short presses (to turn on the PMIC) and long presses (to turn off the PMIC).
Серия: TPS650864 (2)
  • Semiconductors > Power Management > Power Management Multi-Channel IC (PMIC) Solutions
На английском языке: Datasheet Texas Instruments TPS65086470RSKT
