Оптопары и оптореле Megawin
Datasheet Texas Instruments TPS65100QPWPRQ1 — Даташит
СерияTPS65100-Q1
МодельTPS65100QPWPRQ1
Автомобильный блок питания для ЖК-дисплеев от 2,7 В до 5,8 В с повышающим преобразователем, двойным зарядным насосом и контроллером LDO 24-HTSSOP -40 до 125
TPS65100-Q1 Triple-Output LCD Supply With Linear Regulator and VCOM Buffer datasheet
PDF, 1.8 Мб, Версия: C, Файл опубликован: 27 июл 2017
Pin24
Package TypePWP
Industry STD TermHTSSOP
Package QTY2000
Маркировка65100Q
Width (мм)4.4
Length (мм)7.8
Thickness (мм)1
Max Height (мм)1.2
DisplayTypeAutomotive,LCD Unipolar
IC IntegrationLCD Bias
Level Shifter/Scan DriverN/A Ch
Pin/Package24HTSSOP
Source Driver Voltage(Max)15 В
Source Driver Voltage(Min)5 В
Special FunctionVCOM/OpAmp
Target Application7 inches or less,7 to 13 inches
Vin(Max)5.8 В
Vin(Min)2.7 В
  • Evaluation Modules & Boards: TPS65100EVM-030
    TPS65100 Evaluation Module
  • Multi-rails supply regulated outputs to power TFT screen from car battery
    PDF, 500 Кб, Файл опубликован: 16 окт 2012
  • Load Disconnect for the TPS6510x (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 8 фев 2017
    Many boost converters have an external rectifier diode. The input voltage of the TPS6510x main boostconverter is connected to the output voltage when the device is disabled. Due to the direct pass from theinput to the output, the converter has no short-circuit protection. This application report describes how touse a PNP transistor and some passive components to disconnect the boost converte
  • Basic Calculation of an Inverting Buck-Boost Power Stage (Rev. A)
    PDF, 431 Кб, Версия: A, Файл опубликован: 28 авг 2017
    This application note provides basic formulas that you need to design the power stage of an invertingbuck-boost converter. The premise is that the power switch is integrated in the IC and the rectification isdone by a diode (non-synchronous power stage). It provides all the formulas and considerations that youneed to select the external power components such as the inductor the diode and t
  • Understanding Undervoltage Lockout in Power Devices (Rev. A)
    PDF, 90 Кб, Версия: A, Файл опубликован: 19 сен 2018
    Many integrated circuits include an undervoltage lockout (UVLO) function to disable the device at low supply voltages. Below the minimum supply voltage the function and performance of a device may be undefined making it impossible to predict system behavior. This application note explains how to correctly understand the undervoltage lockout specification in the data sheets of TI's power products.
  • Basic Calculation of a Boost Converter's Power Stage (Rev. C)
    PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
    This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed.
Серия: TPS65100-Q1 (1)
  • TPS65100QPWPRQ1
  • Semiconductors > Power Management > LCD/OLED Display Bias Solutions
На английском языке: Datasheet Texas Instruments TPS65100QPWPRQ1
