Datasheet Texas Instruments TPS65105PWPR — Даташит
СерияTPS65105
МодельTPS65105PWPR
4-канальный ЖК-дисплей с полностью интегрируемым положительным зарядным насосом, 3,3 В LDO-регулятором, 0,96 А мин.
TPS6510x Triple Output LCD Supply With Linear Regulator and VCOM Buffer datasheet
PDF, 1.7 Мб, Версия: D, Файл опубликован: 31 авг 2016
повышающий Ilim, Fault и VCOM 24-HTSSOP от -40 до 85
Pin24
Package TypePWP
Industry STD TermHTSSOP
Package QTY2000
МаркировкаTPS65105
Width (мм)4.4
Length (мм)7.8
Thickness (мм)1
Max Height (мм)1.2
DisplayTypeLCD Unipolar
IC IntegrationLCD Bias
Level Shifter/Scan DriverN/A Ch
Pin/Package24HTSSOP, 24VQFN
Source Driver Voltage(Max)15 В
Source Driver Voltage(Min)5 В
Special FunctionVCOM/OpAmp
Target Application7 inches or less,7 to 13 inches
Vin(Max)5.8 В
Vin(Min)2.7 В
  • Evaluation Modules & Boards: TPS65140EVM-031
    TPS65140 Evaluation Module
  • Evaluation Modules & Boards: TPS65100EVM-030
    TPS65100 Evaluation Module
  • Load Disconnect for the TPS6510x (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 8 фев 2017
    Many boost converters have an external rectifier diode. The input voltage of the TPS6510x main boostconverter is connected to the output voltage when the device is disabled. Due to the direct pass from theinput to the output, the converter has no short-circuit protection. This application report describes how touse a PNP transistor and some passive components to disconnect the boost converte
  • Customizing your TPS6510x/TPS6514X
    PDF, 233 Кб, Файл опубликован: 22 июн 2004
    This application report shows how to use external circuitry to boost the output voltage capability of the positive and negative charge pumps of the TPS6510x and TPS6514x triple output power supplies. In addition the report shows how to use external circuitry to modify the internally controlled sequencing implement sequencing delay and short circuit protection.
  • How to Compensate the TPS6510x and the TPS6514x
    PDF, 1.1 Мб, Файл опубликован: 30 авг 2016
    The boost converters in the TPS6510x (TPS65100 TPS65101 TPS65105) and the TPS6514x (TPS65140 TPS65141 TPS65145) series use external loop compensation providing high flexibility in LCD supply design. If designing a typical application scheme use the recommended components from the TPS6510x datasheet (SLVS496) and the TPS6514x datasheet (SLVS497). This application note gives a deeper understand
  • Basic Calculation of an Inverting Buck-Boost Power Stage (Rev. A)
    PDF, 431 Кб, Версия: A, Файл опубликован: 28 авг 2017
    This application note provides basic formulas that you need to design the power stage of an invertingbuck-boost converter. The premise is that the power switch is integrated in the IC and the rectification isdone by a diode (non-synchronous power stage). It provides all the formulas and considerations that youneed to select the external power components such as the inductor the diode and t
  • Generation of a VCOM buffer input using PWM signal
    PDF, 439 Кб, Файл опубликован: 21 дек 2015
    In an LCD the backlight shines through the liquid crystal material and the voltage across the liquid crystal controls how much light shines through it. An active matrix LCD (AMLCD) contains many pixels arranged in a grid pattern. The voltage across each pixel is controlled individually so that high resolution images can be created. One terminal of every pixel is connected to a common plane. The v
  • Understanding Undervoltage Lockout in Power Devices (Rev. A)
    PDF, 90 Кб, Версия: A, Файл опубликован: 19 сен 2018
    Many integrated circuits include an undervoltage lockout (UVLO) function to disable the device at low supply voltages. Below the minimum supply voltage the function and performance of a device may be undefined making it impossible to predict system behavior. This application note explains how to correctly understand the undervoltage lockout specification in the data sheets of TI's power products.
  • Minimizing Ringing at the Switch Node of a Boost Converter
    PDF, 201 Кб, Файл опубликован: 15 сен 2006
    The application report explains how to use proper board layout and/or a snubber to reduce high-frequency ringing at the switch node of a boost converter.
  • Basic Calculation of a Boost Converter's Power Stage (Rev. C)
    PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
    This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed.
Серия: TPS65105 (5)
  • Semiconductors > Power Management > LCD/OLED Display Bias Solutions
На английском языке: Datasheet Texas Instruments TPS65105PWPR
