Datasheet Texas Instruments TPS65124RGTTG4 — Даташит
СерияTPS65124
МодельTPS65124RGTTG4
3-канальная одноиндукторная многовыходная (SIMO) ИС смещения с регулируемой последовательностью 16-VQFN -40 до 85
Single-Inductor Quadruple-Output TFT LCD Power Supply datasheet
PDF, 1.5 Мб, Версия: A, Файл опубликован: 28 мар 2005
Pin16
Package TypeRGT
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY250
CarrierSMALL T&R
МаркировкаBKD
Width (мм)3
Length (мм)3
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
DisplayTypeLCD Unipolar
IC IntegrationLCD Bias
Level Shifter/Scan DriverN/A Ch
Pin/Package16VQFN
Source Driver Voltage(Max)5.6 В
Source Driver Voltage(Min)3 В
Special FunctionAdjustable Sequencing,Output Discharge
Target Application7 inches or less
V_NEG(Max)-1.5 В
V_NEG(Min)-18 В
V_POS(Max)20 В
V_POS(Min)3 В
Vin(Max)5.5 В
Vin(Min)2.5 В
  • Evaluation Modules & Boards: TPS65124EVM-076
    TPS65124 Evaluation Module
  • Evaluation Modules & Boards: TPS65120EVM-076
    TPS65120 Evaluation Module
  • Basic Calculation of an Inverting Buck-Boost Power Stage (Rev. A)
    PDF, 431 Кб, Версия: A, Файл опубликован: 28 авг 2017
    This application note provides basic formulas that you need to design the power stage of an invertingbuck-boost converter. The premise is that the power switch is integrated in the IC and the rectification isdone by a diode (non-synchronous power stage). It provides all the formulas and considerations that youneed to select the external power components such as the inductor the diode and t
  • Generation of a VCOM buffer input using PWM signal
    PDF, 439 Кб, Файл опубликован: 21 дек 2015
    In an LCD the backlight shines through the liquid crystal material and the voltage across the liquid crystal controls how much light shines through it. An active matrix LCD (AMLCD) contains many pixels arranged in a grid pattern. The voltage across each pixel is controlled individually so that high resolution images can be created. One terminal of every pixel is connected to a common plane. The v
  • Understanding Undervoltage Lockout in Power Devices (Rev. A)
    PDF, 90 Кб, Версия: A, Файл опубликован: 19 сен 2018
    Many integrated circuits include an undervoltage lockout (UVLO) function to disable the device at low supply voltages. Below the minimum supply voltage the function and performance of a device may be undefined making it impossible to predict system behavior. This application note explains how to correctly understand the undervoltage lockout specification in the data sheets of TI's power products.
  • Basic Calculation of a Boost Converter's Power Stage (Rev. C)
    PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
    This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed.
  • Basic Calculation of a Buck Converter's Power Stage (Rev. B)
    PDF, 202 Кб, Версия: B, Файл опубликован: 17 авг 2015
Серия: TPS65124 (4)
  • Semiconductors > Power Management > LCD/OLED Display Bias Solutions
На английском языке: Datasheet Texas Instruments TPS65124RGTTG4
