Datasheet Texas Instruments TPS65136RTERG4 — Даташит
СерияTPS65136
МодельTPS65136RTERG4
Один индуктор с несколькими выходами (SIMO) для положительного и отрицательного выхода 16-WQFN -40 до 85
Single Inductor Multiple Output Regulator for AMOLED datasheet
PDF, 1.1 Мб, Версия: A, Файл опубликован: 7 июл 2008
Pin16
Package TypeRTE
Industry STD TermWQFN
JEDEC CodeS-PQFP-N
Package QTY3000
МаркировкаCCO
Width (мм)3
Length (мм)3
Thickness (мм).75
Pitch (мм).5
Max Height (мм).8
DisplayTypeAMOLED
IC IntegrationAMOLED Bias
Level Shifter/Scan DriverN/A Ch
Pin/Package16WQFN
Special FunctionN/A
Target Application7 inches or less
V_NEG(Max)-2.5 В
V_NEG(Min)-6 В
V_POS(Max)4.6 В
V_POS(Min)4.6 В
Vin(Max)5.5 В
Vin(Min)2.3 В
  • Evaluation Modules & Boards: TPS65136EVM-265
    TPS65136EVM-265 Evaluation Module
  • Basic Calculation of an Inverting Buck-Boost Power Stage (Rev. A)
    PDF, 431 Кб, Версия: A, Файл опубликован: 28 авг 2017
    This application note provides basic formulas that you need to design the power stage of an invertingbuck-boost converter. The premise is that the power switch is integrated in the IC and the rectification isdone by a diode (non-synchronous power stage). It provides all the formulas and considerations that youneed to select the external power components such as the inductor the diode and t
  • Understanding Undervoltage Lockout in Power Devices (Rev. A)
    PDF, 90 Кб, Версия: A, Файл опубликован: 19 сен 2018
    Many integrated circuits include an undervoltage lockout (UVLO) function to disable the device at low supply voltages. Below the minimum supply voltage the function and performance of a device may be undefined making it impossible to predict system behavior. This application note explains how to correctly understand the undervoltage lockout specification in the data sheets of TI's power products.
  • Basic Calculation of a Boost Converter's Power Stage (Rev. C)
    PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
    This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed.
  • Basic Calculation of a Buck Converter's Power Stage (Rev. B)
    PDF, 202 Кб, Версия: B, Файл опубликован: 17 авг 2015
Серия: TPS65136 (2)
  • Semiconductors > Power Management > LCD/OLED Display Bias Solutions
На английском языке: Datasheet Texas Instruments TPS65136RTERG4
