Datasheet Texas Instruments TPS65137ASDSCR — Даташит
СерияTPS65137AS
МодельTPS65137ASDSCR
Блок питания для дисплея AMOLED с двумя выходами 250 мА 10-WSON -40 to 85
250mA Dual Outputs AMOLED Display Power Supply datasheet
PDF, 1.0 Мб, Версия: B, Файл опубликован: 5 сен 2013
Pin10
Package TypeDSC
Industry STD TermWSON
JEDEC CodeS-PDSO-N
Package QTY3000
МаркировкаPPGC
Width (мм)3
Length (мм)3
Thickness (мм).75
Pitch (мм).5
Max Height (мм).8
DisplayTypeN/A
IC IntegrationAMOLED Bias
Level Shifter/Scan DriverN/A Ch
Pin/Package10WSON
Special FunctionDigital Control I/F
Target Application7 inches or less
V_NEG(Max)-2.2 В
V_NEG(Min)-5.2 В
V_POS(Max)4.6 В
V_POS(Min)4.6 В
Vin(Max)4.8 В
Vin(Min)2.5 В
  • Basic Calculation of an Inverting Buck-Boost Power Stage (Rev. A)
    PDF, 431 Кб, Версия: A, Файл опубликован: 28 авг 2017
    This application note provides basic formulas that you need to design the power stage of an invertingbuck-boost converter. The premise is that the power switch is integrated in the IC and the rectification isdone by a diode (non-synchronous power stage). It provides all the formulas and considerations that youneed to select the external power components such as the inductor the diode and t
  • Understanding Undervoltage Lockout in Power Devices (Rev. A)
    PDF, 90 Кб, Версия: A, Файл опубликован: 19 сен 2018
    Many integrated circuits include an undervoltage lockout (UVLO) function to disable the device at low supply voltages. Below the minimum supply voltage the function and performance of a device may be undefined making it impossible to predict system behavior. This application note explains how to correctly understand the undervoltage lockout specification in the data sheets of TI's power products.
Серия: TPS65137AS (1)
  • TPS65137ASDSCR
  • Semiconductors > Power Management > LCD/OLED Display Bias Solutions
На английском языке: Datasheet Texas Instruments TPS65137ASDSCR
