Datasheet Texas Instruments TPS65138ADRCR — Даташит
СерияTPS65138
МодельTPS65138ADRCR
Блок питания для дисплея AMOLED с двумя выходами 10-VSON -40 to 85
Dual output AMOLED display power supply . datasheet
PDF, 1.1 Мб, Версия: C, Файл опубликован: 6 мар 2013
26 предложений от 17 поставщиков
Интегральные микросхемы Микросхемы управления электропитанием - Устройства управления дисплеем
TPS65138ADRCR
30 ₽
TPS65138ADRCR
84 ₽
ТаймЧипс
TPS65138ADRCR
727GS
TPS65138ADRCR
Pin10
Package TypeDRC
Industry STD TermVSON
JEDEC CodeS-PDSO-N
Package QTY3000
МаркировкаPXJI
Width (мм)3
Length (мм)3
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
DisplayTypeAMOLED
IC IntegrationAMOLED Bias
Level Shifter/Scan DriverN/A Ch
Pin/Package10VSON
Special FunctionDigital Control I/F
Target Application7 inches or less
V_NEG(Max)-2.2 В
V_NEG(Min)-6.2 В
V_POS(Max)4.62 В
V_POS(Min)4.62 В
Vin(Max)4.5 В
Vin(Min)2.9 В
  • Basic Calculation of an Inverting Buck-Boost Power Stage (Rev. A)
    PDF, 431 Кб, Версия: A, Файл опубликован: 28 авг 2017
    This application note provides basic formulas that you need to design the power stage of an invertingbuck-boost converter. The premise is that the power switch is integrated in the IC and the rectification isdone by a diode (non-synchronous power stage). It provides all the formulas and considerations that youneed to select the external power components such as the inductor the diode and t
  • Understanding Undervoltage Lockout in Power Devices (Rev. A)
    PDF, 90 Кб, Версия: A, Файл опубликован: 19 сен 2018
    Many integrated circuits include an undervoltage lockout (UVLO) function to disable the device at low supply voltages. Below the minimum supply voltage the function and performance of a device may be undefined making it impossible to predict system behavior. This application note explains how to correctly understand the undervoltage lockout specification in the data sheets of TI's power products.
  • Basic Calculation of a Buck Converter's Power Stage (Rev. B)
    PDF, 202 Кб, Версия: B, Файл опубликован: 17 авг 2015
Серия: TPS65138 (2)
  • Semiconductors > Power Management > LCD/OLED Display Bias Solutions
На английском языке: Datasheet Texas Instruments TPS65138ADRCR
