Datasheet Texas Instruments TPS65145IPWPRQ1 — Даташит
СерияTPS65145-Q1
МодельTPS65145IPWPRQ1
Автомобильный 2,7 В - 5,8 В, 4-канальный блок питания для ЖК-дисплеев с обнаружением неисправностей 24-HTSSOP -40 - 85
TPS65140-Q1 Triple Output LCD Supply With Linear Regulator & Power Good datasheet
PDF, 723 Кб, Версия: B, Файл опубликован: 31 июл 2017
Pin24
Package TypePWP
Industry STD TermHTSSOP
Package QTY2000
Маркировка65145IQ1
Width (мм)4.4
Length (мм)7.8
Thickness (мм)1
Max Height (мм)1.2
DisplayTypeAutomotive,LCD Unipolar
IC IntegrationLCD Bias
Level Shifter/Scan DriverN/A Ch
Pin/Package24HTSSOP
Source Driver Voltage(Max)15 В
Source Driver Voltage(Min)5 В
Special FunctionN/A
Target Application7 to 13 inches,13 to 21 inches
Vin(Max)5.8 В
Vin(Min)2.7 В
  • Multi-rails supply regulated outputs to power TFT screen from car battery
    PDF, 500 Кб, Файл опубликован: 16 окт 2012
  • Basic Calculation of an Inverting Buck-Boost Power Stage (Rev. A)
    PDF, 431 Кб, Версия: A, Файл опубликован: 28 авг 2017
    This application note provides basic formulas that you need to design the power stage of an invertingbuck-boost converter. The premise is that the power switch is integrated in the IC and the rectification isdone by a diode (non-synchronous power stage). It provides all the formulas and considerations that youneed to select the external power components such as the inductor the diode and t
  • Understanding Undervoltage Lockout in Power Devices (Rev. A)
    PDF, 90 Кб, Версия: A, Файл опубликован: 19 сен 2018
    Many integrated circuits include an undervoltage lockout (UVLO) function to disable the device at low supply voltages. Below the minimum supply voltage the function and performance of a device may be undefined making it impossible to predict system behavior. This application note explains how to correctly understand the undervoltage lockout specification in the data sheets of TI's power products.
  • Minimizing Ringing at the Switch Node of a Boost Converter
    PDF, 201 Кб, Файл опубликован: 15 сен 2006
    The application report explains how to use proper board layout and/or a snubber to reduce high-frequency ringing at the switch node of a boost converter.
  • Basic Calculation of a Boost Converter's Power Stage (Rev. C)
    PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
    This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed.
Серия: TPS65145-Q1 (1)
  • TPS65145IPWPRQ1
  • Semiconductors > Power Management > LCD/OLED Display Bias Solutions
На английском языке: Datasheet Texas Instruments TPS65145IPWPRQ1
