Datasheet Texas Instruments TPS65146RGER — Даташит
СерияTPS65146
МодельTPS65146RGER
3-CH LCD Bias w/ LDO, GPM, VCOM Buffer & Reset ICВ  24-VQFN -40 to 85
Compact LCD Bias IC for Notebook & Monitor with LDO, VCOM Buffer and Reset IC datasheet
PDF, 2.3 Мб, Версия: A, Файл опубликован: 16 июн 2009
Pin24
Package TypeRGE
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY3000
Width (мм)4
Length (мм)4
Thickness (мм)0.88
Pitch (мм)0.5
Max Height (мм)1
DisplayTypeN/A
IC IntegrationLCD Bias,VCOM
Pin/Package24VQFN
Source Driver Voltage(Max)16.5 В
Source Driver Voltage(Min)7 В
Special FunctionGPM/GVS,Output Discharge,Reset Generator,VCOM/OpAmp
Target Application13 to 21 inches
TopologyBoost,Inverting Buck-Boost
Vin(Max)6 В
Vin(Min)2.5 В
  • Generation of a VCOM buffer input using PWM signal
    PDF, 439 Кб, Файл опубликован: 21 дек 2015
    In an LCD the backlight shines through the liquid crystal material and the voltage across the liquid crystal controls how much light shines through it. An active matrix LCD (AMLCD) contains many pixels arranged in a grid pattern. The voltage across each pixel is controlled individually so that high resolution images can be created. One terminal of every pixel is connected to a common plane. The v
  • Understanding Undervoltage Lockout in Power Devices (Rev. A)
    PDF, 90 Кб, Версия: A, Файл опубликован: 19 сен 2018
    Many integrated circuits include an undervoltage lockout (UVLO) function to disable the device at low supply voltages. Below the minimum supply voltage the function and performance of a device may be undefined making it impossible to predict system behavior. This application note explains how to correctly understand the undervoltage lockout specification in the data sheets of TI's power products.
  • Minimizing Ringing at the Switch Node of a Boost Converter
    PDF, 201 Кб, Файл опубликован: 15 сен 2006
    The application report explains how to use proper board layout and/or a snubber to reduce high-frequency ringing at the switch node of a boost converter.
Серия: TPS65146 (1)
  • TPS65146RGER
  • Semiconductors > Power Management > LCD/OLED Display Bias Solutions
На английском языке: Datasheet Texas Instruments TPS65146RGER
