Datasheet Texas Instruments TPS65148RHBR — Даташит
СерияTPS65148
МодельTPS65148RHBR
4-канальный ЖК-дисплей со смещением GPM, VCOM, сбросом, разрядкой ЖК-дисплея, HVS, внешним изолирующим переключателем и LDO для Gamma 32-VQFN -40 до 85
Compact TFT LCD Bias IC with VCOM Buffer, Voltage Regulator and Reset Function datasheet
PDF, 1.3 Мб, Версия: A, Файл опубликован: 19 янв 2011
Чип стабилизации напряжения, 4CH LCD Bias w/ GPM, VCOM, Reset, LCD Discharge, HVS, Ext. Isolation Switch & LDO for Gamma 32-VQFN...
TPS65148RHBR
44 ₽
TPS65148RHBR
131 ₽
TPS65148RHBR
140 ₽
LifeElectronics
TPS65148RHBR
Pin32
Package TypeRHB
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY3000
Width (мм)5
Length (мм)5
Thickness (мм)0.9
Pitch (мм)0.5
Max Height (мм)1
DisplayTypeLCD Unipolar
IC IntegrationLCD Bias,VCOM
Pin/Package32VQFN
Source Driver Voltage(Max)18 В
Source Driver Voltage(Min)7 В
Special FunctionGPM/GVS,Output Discharge,Reset Generator,VCOM/OpAmp
Target Application13 to 21 inches,7 to 13 inches
TopologyBoost
Vin(Max)6 В
Vin(Min)2.5 В
  • Generation of a VCOM buffer input using PWM signal
    PDF, 439 Кб, Файл опубликован: 21 дек 2015
    In an LCD the backlight shines through the liquid crystal material and the voltage across the liquid crystal controls how much light shines through it. An active matrix LCD (AMLCD) contains many pixels arranged in a grid pattern. The voltage across each pixel is controlled individually so that high resolution images can be created. One terminal of every pixel is connected to a common plane. The v
  • Understanding Undervoltage Lockout in Power Devices (Rev. A)
    PDF, 90 Кб, Версия: A, Файл опубликован: 19 сен 2018
    Many integrated circuits include an undervoltage lockout (UVLO) function to disable the device at low supply voltages. Below the minimum supply voltage the function and performance of a device may be undefined making it impossible to predict system behavior. This application note explains how to correctly understand the undervoltage lockout specification in the data sheets of TI's power products.
Серия: TPS65148 (1)
  • TPS65148RHBR
  • Semiconductors > Power Management > LCD/OLED Display Bias Solutions
На английском языке: Datasheet Texas Instruments TPS65148RHBR
