Datasheet Texas Instruments TPS65149RSHR — Даташит
СерияTPS65149
МодельTPS65149RSHR
Решение смещения ЖК-дисплеев для ЖК-панелей с использованием технологии ASG/GIP 56-VQFN -40 до 85
TPS65149 LCD Bias Solution for LCD Monitors - request datasheet datasheet
PDF, 223 Кб, Файл опубликован: 19 авг 2010
Pin56
Package TypeRSH
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY2500
Width (мм)7
Length (мм)7
Thickness (мм)0.9
Pitch (мм)0.4
Max Height (мм)1
DisplayTypeLCD Unipolar
IC IntegrationLCD Bias,LCD Level shifter,VCOM
Level Shifter/Scan Driver8 Ch
Pin/Package56VQFN
Source Driver Voltage(Max)18 В
Source Driver Voltage(Min)7 В
Special FunctionI2C I/F,Level Shifter,Output Discharge,Reset Generator,Temperature Sensor/Compensation,VCOM/OpAmp
Target Application13 to 21 inches,21 inches and above
TopologyBoost
Vin(Max)6 В
Vin(Min)3 В
  • Understanding Undervoltage Lockout in Power Devices (Rev. A)
    PDF, 90 Кб, Версия: A, Файл опубликован: 19 сен 2018
    Many integrated circuits include an undervoltage lockout (UVLO) function to disable the device at low supply voltages. Below the minimum supply voltage the function and performance of a device may be undefined making it impossible to predict system behavior. This application note explains how to correctly understand the undervoltage lockout specification in the data sheets of TI's power products.
  • Minimizing Ringing at the Switch Node of a Boost Converter
    PDF, 201 Кб, Файл опубликован: 15 сен 2006
    The application report explains how to use proper board layout and/or a snubber to reduce high-frequency ringing at the switch node of a boost converter.
Серия: TPS65149 (1)
  • TPS65149RSHR
  • Semiconductors > Power Management > LCD/OLED Display Bias Solutions
На английском языке: Datasheet Texas Instruments TPS65149RSHR
