Линейка продуктов KEEN SIDE
Datasheet Texas Instruments TPS65150PWPG4 — Даташит
СерияTPS65150
МодельTPS65150PWPG4
Универсальный, компактный блок питания смещения ЖК-дисплея со встроенным буфером VCOM 24-HTSSOP от -40 до 85
TPS65150 Low Input Voltage, Compact LCD Bias IC With VCOM Buffer datasheet
PDF, 1.7 Мб, Версия: B, Файл опубликован: 7 янв 2016
Pin24
Package TypePWP
Industry STD TermHTSSOP
Package QTY60
Width (мм)4.4
Length (мм)7.8
Thickness (мм)1
Pitch (мм)0.65
Max Height (мм)1.2
DisplayTypeLCD Unipolar
IC IntegrationLCD Bias,VCOM
Pin/Package24HTSSOP, 24VQFN
Source Driver Voltage(Max)15 В
Special FunctionAdjustable Sequencing,GPM/GVS,VCOM/OpAmp
Target Application7 inches or less,7 to 13 inches
TopologyBoost
Vin(Max)6 В
Vin(Min)1.8 В
  • Evaluation Modules & Boards: TPS65150EVM-697
    TPS65150 Low Vin LCD power supply (bias) with integrated VCOM Evaluation Module
  • How to Calculate the Output Voltage Ranges of the Charge Pumps in the TPS65150
    PDF, 265 Кб, Файл опубликован: 6 фев 2017
    This application report tells you how to estimate the output voltage range of the charge pumps in theTPS65150. It assumes that the output current from each charge pump is 25 mA or less.This application report was written specifically for the TPS65150 but the principles in it are applicable toall devices that use the same charge-pump topology.
  • Generation of a VCOM buffer input using PWM signal
    PDF, 439 Кб, Файл опубликован: 21 дек 2015
    In an LCD the backlight shines through the liquid crystal material and the voltage across the liquid crystal controls how much light shines through it. An active matrix LCD (AMLCD) contains many pixels arranged in a grid pattern. The voltage across each pixel is controlled individually so that high resolution images can be created. One terminal of every pixel is connected to a common plane. The v
  • Understanding Undervoltage Lockout in Power Devices (Rev. A)
    PDF, 90 Кб, Версия: A, Файл опубликован: 19 сен 2018
    Many integrated circuits include an undervoltage lockout (UVLO) function to disable the device at low supply voltages. Below the minimum supply voltage the function and performance of a device may be undefined making it impossible to predict system behavior. This application note explains how to correctly understand the undervoltage lockout specification in the data sheets of TI's power products.
  • Minimizing Ringing at the Switch Node of a Boost Converter
    PDF, 201 Кб, Файл опубликован: 15 сен 2006
    The application report explains how to use proper board layout and/or a snubber to reduce high-frequency ringing at the switch node of a boost converter.
  • Basic Calculation of a Boost Converter's Power Stage (Rev. C)
    PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
    This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed.
Серия: TPS65150 (6)
  • Semiconductors > Power Management > LCD/OLED Display Bias Solutions
На английском языке: Datasheet Texas Instruments TPS65150PWPG4
