Datasheet Texas Instruments TPS65150PWPRG4 — Даташит
| Серия | TPS65150 |
| Модель | TPS65150PWPRG4 |
Универсальный, компактный блок питания смещения ЖК-дисплея со встроенным буфером VCOM 24-HTSSOP от -40 до 85
TPS65150 Low Input Voltage, Compact LCD Bias IC With VCOM Buffer datasheet
PDF, 1.7 Мб, Версия: B, Файл опубликован: 7 янв 2016
Купить TPS65150PWPRG4 на РадиоЛоцман.Цены — от 51 до 387 ₽12 предложений от 12 поставщиков IC TRIPLE-OUT LCD SPPLY 24HTSSOP. LCD Monitor, Notebook Display PMIC 24-HTSSOP. PMIC - Power Management - Specialized | |||
| TPS65150PWPRG4 Texas Instruments | 51 ₽ | ||
| TPS65150PWPRG4 Texas Instruments | 76 ₽ | ||
| TPS65150PWPRG4 Texas Instruments | 93 ₽ | ||
| TPS65150PWPRG4 Texas Instruments | по запросу | ||
| Pin | 24 |
| Package Type | PWP |
| Industry STD Term | HTSSOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2000 |
| Carrier | LARGE T&R |
| Width (мм) | 4.4 |
| Length (мм) | 7.8 |
| Thickness (мм) | 1 |
| Pitch (мм) | 0.65 |
| Max Height (мм) | 1.2 |
| Mechanical Data | Скачать |
| DisplayType | LCD Unipolar |
| IC Integration | LCD Bias,VCOM |
| Pin/Package | 24HTSSOP, 24VQFN |
| Source Driver Voltage(Max) | 15 В |
| Special Function | Adjustable Sequencing,GPM/GVS,VCOM/OpAmp |
| Target Application | 7 inches or less,7 to 13 inches |
| Topology | Boost |
| Vin(Max) | 6 В |
| Vin(Min) | 1.8 В |
- Evaluation Modules & Boards: TPS65150EVM-697
TPS65150 Low Vin LCD power supply (bias) with integrated VCOM Evaluation Module
- How to Calculate the Output Voltage Ranges of the Charge Pumps in the TPS65150PDF, 265 Кб, Файл опубликован: 6 фев 2017
This application report tells you how to estimate the output voltage range of the charge pumps in theTPS65150. It assumes that the output current from each charge pump is 25 mA or less.This application report was written specifically for the TPS65150 but the principles in it are applicable toall devices that use the same charge-pump topology. - Generation of a VCOM buffer input using PWM signalPDF, 439 Кб, Файл опубликован: 21 дек 2015
In an LCD the backlight shines through the liquid crystal material and the voltage across the liquid crystal controls how much light shines through it. An active matrix LCD (AMLCD) contains many pixels arranged in a grid pattern. The voltage across each pixel is controlled individually so that high resolution images can be created. One terminal of every pixel is connected to a common plane. The v - Understanding Undervoltage Lockout in Power Devices (Rev. A)PDF, 90 Кб, Версия: A, Файл опубликован: 19 сен 2018
Many integrated circuits include an undervoltage lockout (UVLO) function to disable the device at low supply voltages. Below the minimum supply voltage the function and performance of a device may be undefined making it impossible to predict system behavior. This application note explains how to correctly understand the undervoltage lockout specification in the data sheets of TI's power products. - Minimizing Ringing at the Switch Node of a Boost ConverterPDF, 201 Кб, Файл опубликован: 15 сен 2006
The application report explains how to use proper board layout and/or a snubber to reduce high-frequency ringing at the switch node of a boost converter. - Basic Calculation of a Boost Converter's Power Stage (Rev. C)PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed.
Серия: TPS65150 (6)
- TPS65150PWP TPS65150PWPG4 TPS65150PWPR TPS65150PWPRG4 TPS65150RGER TPS65150RGERG4
- Semiconductors > Power Management > LCD/OLED Display Bias Solutions
