Datasheet Texas Instruments TPS65155RKPR — Даташит
СерияTPS65155
МодельTPS65155RKPR
Решение смещения ЖК-дисплея с преобразователями уровня для панелей GOA 40-VQFN -40 до 85
TPS65155 LCD Bias Solution for LCD Monitors datasheet
PDF, 191 Кб, Файл опубликован: 27 сен 2017
Pin40
Package TypeRKP
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY3000
Width (мм)5
Length (мм)5
Thickness (мм)0.9
Pitch (мм)0.4
Max Height (мм)1
DisplayTypeLCD Unipolar
IC IntegrationLCD Bias,LCD Level shifter
Level Shifter/Scan Driver6 Ch
Pin/Package40VQFN
Source Driver Voltage(Max)18 В
Source Driver Voltage(Min)7 В
Special FunctionI2C I/F,Level Shifter,Output Discharge,Reset Generator,Temperature Sensor/Compensation
Target Application13 to 21 inches,7 to 13 inches
TopologyBoost
Vin(Max)6 В
Vin(Min)3 В
  • Generation of a VCOM buffer input using PWM signal
    PDF, 439 Кб, Файл опубликован: 21 дек 2015
    In an LCD the backlight shines through the liquid crystal material and the voltage across the liquid crystal controls how much light shines through it. An active matrix LCD (AMLCD) contains many pixels arranged in a grid pattern. The voltage across each pixel is controlled individually so that high resolution images can be created. One terminal of every pixel is connected to a common plane. The v
  • Understanding Undervoltage Lockout in Power Devices (Rev. A)
    PDF, 90 Кб, Версия: A, Файл опубликован: 19 сен 2018
    Many integrated circuits include an undervoltage lockout (UVLO) function to disable the device at low supply voltages. Below the minimum supply voltage the function and performance of a device may be undefined making it impossible to predict system behavior. This application note explains how to correctly understand the undervoltage lockout specification in the data sheets of TI's power products.
  • Minimizing Ringing at the Switch Node of a Boost Converter
    PDF, 201 Кб, Файл опубликован: 15 сен 2006
    The application report explains how to use proper board layout and/or a snubber to reduce high-frequency ringing at the switch node of a boost converter.
  • Basic Calculation of a Boost Converter's Power Stage (Rev. C)
    PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
    This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed.
Серия: TPS65155 (1)
  • TPS65155RKPR
  • Semiconductors > Power Management > LCD/OLED Display Bias Solutions
На английском языке: Datasheet Texas Instruments TPS65155RKPR
