Datasheet Texas Instruments TPS65165RSBR — Даташит
СерияTPS65165
МодельTPS65165RSBR
4-канальный ЖК-дисплей с полностью интегрируемым положительным зарядным насосом, 3,3 В LDO-регулятором, 0,96 А мин.
Compact LCD Bias IC w/High Speed Amp for TV & Monitor TFT-LCD Panels datasheet
PDF, 1.3 Мб, Версия: A, Файл опубликован: 25 май 2007
предельный ток повышения и обнаружение неисправностей 40-WQFN -40 to 85
Pin40
Package TypeRSB
Industry STD TermWQFN
JEDEC CodeS-PQFP-N
Package QTY3000
Width (мм)5
Length (мм)5
Thickness (мм)0.75
Pitch (мм)0.4
Max Height (мм)0.8
DisplayTypeN/A
IC IntegrationLCD Bias,VCOM
Pin/Package40WQFN
Source Driver Voltage(Max)18 В
Source Driver Voltage(Min)7 В
Special FunctionGPM/GVS,VCOM/OpAmp
Target Application13 to 21 inches,7 to 13 inches
TopologyBoost
Vin(Max)6 В
Vin(Min)2.5 В
  • Evaluation Modules & Boards: TPS65165EVM-233
    TPS65165 Evaluation Module
  • Generation of a VCOM buffer input using PWM signal
    PDF, 439 Кб, Файл опубликован: 21 дек 2015
    In an LCD the backlight shines through the liquid crystal material and the voltage across the liquid crystal controls how much light shines through it. An active matrix LCD (AMLCD) contains many pixels arranged in a grid pattern. The voltage across each pixel is controlled individually so that high resolution images can be created. One terminal of every pixel is connected to a common plane. The v
  • Understanding Undervoltage Lockout in Power Devices (Rev. A)
    PDF, 90 Кб, Версия: A, Файл опубликован: 19 сен 2018
    Many integrated circuits include an undervoltage lockout (UVLO) function to disable the device at low supply voltages. Below the minimum supply voltage the function and performance of a device may be undefined making it impossible to predict system behavior. This application note explains how to correctly understand the undervoltage lockout specification in the data sheets of TI's power products.
  • Minimizing Ringing at the Switch Node of a Boost Converter
    PDF, 201 Кб, Файл опубликован: 15 сен 2006
    The application report explains how to use proper board layout and/or a snubber to reduce high-frequency ringing at the switch node of a boost converter.
Серия: TPS65165 (1)
  • TPS65165RSBR
  • Semiconductors > Power Management > LCD/OLED Display Bias Solutions
На английском языке: Datasheet Texas Instruments TPS65165RSBR
