Datasheet Texas Instruments TPS65167ARHAR — Даташит
СерияTPS65167A
МодельTPS65167ARHAR
4-канальный ЖК-дисплей с полностью интегрированным положительным зарядным насосом, контроллером LDO, HVS (VDD / VGH) и датчиком температуры 40-VQFN -40 to 85
Compact LCD Bias Supply for TFT-LCD TV Panels datasheet
PDF, 1.6 Мб, Версия: C, Файл опубликован: 10 мар 2008
Pin40
Package TypeRHA
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY2500
Width (мм)6
Length (мм)6
Thickness (мм)0.9
Pitch (мм)0.5
Max Height (мм)1
DisplayTypeLCD Unipolar
IC IntegrationLCD Bias
Pin/Package40VQFN
Source Driver Voltage(Max)19 В
Special FunctionOutput Discharge,GPM/GVS,Temperature Sensor/Compensation
Target Application13 to 21 inches,21 inches and above
TopologyBoost,Buck
Vin(Max)14 В
Vin(Min)6 В
  • Evaluation Modules & Boards: TPS65167EVM-277
    TPS65167 Evaluation Module
  • Generation of a VCOM buffer input using PWM signal
    PDF, 439 Кб, Файл опубликован: 21 дек 2015
    In an LCD the backlight shines through the liquid crystal material and the voltage across the liquid crystal controls how much light shines through it. An active matrix LCD (AMLCD) contains many pixels arranged in a grid pattern. The voltage across each pixel is controlled individually so that high resolution images can be created. One terminal of every pixel is connected to a common plane. The v
  • Understanding Undervoltage Lockout in Power Devices (Rev. A)
    PDF, 90 Кб, Версия: A, Файл опубликован: 19 сен 2018
    Many integrated circuits include an undervoltage lockout (UVLO) function to disable the device at low supply voltages. Below the minimum supply voltage the function and performance of a device may be undefined making it impossible to predict system behavior. This application note explains how to correctly understand the undervoltage lockout specification in the data sheets of TI's power products.
  • Minimizing Ringing at the Switch Node of a Boost Converter
    PDF, 201 Кб, Файл опубликован: 15 сен 2006
    The application report explains how to use proper board layout and/or a snubber to reduce high-frequency ringing at the switch node of a boost converter.
  • Basic Calculation of a Boost Converter's Power Stage (Rev. C)
    PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
    This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed.
  • Basic Calculation of a Buck Converter's Power Stage (Rev. B)
    PDF, 202 Кб, Версия: B, Файл опубликован: 17 авг 2015
Серия: TPS65167A (1)
  • TPS65167ARHAR
  • Semiconductors > Power Management > LCD/OLED Display Bias Solutions
На английском языке: Datasheet Texas Instruments TPS65167ARHAR
