Datasheet Texas Instruments TPS65176RHDR — Даташит
СерияTPS65176
МодельTPS65176RHDR
ЖК-дисплей смещения ИС для телевизора 28-VQFN -40 до 85
LCD Bias Integrated Circuit for TV datasheet
PDF, 699 Кб, Файл опубликован: 16 окт 2012
Интегральные микросхемы Микросхемы управления электропитанием - Управление питанием - Специальные
TPS65176RHDR
121 ₽
Зенер
Россия и страны ТС
TPS65176RHDR
от 296 ₽
TPS65176RHDR
301 ₽
TPS65176RHDR
Pin28
Package TypeRHD
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY3000
Width (мм)5
Length (мм)5
Thickness (мм)0.9
Pitch (мм)0.5
Max Height (мм)1
DisplayTypeLCD Unipolar
IC IntegrationLCD Bias
Pin/Package28VQFN
Source Driver Voltage(Max)18.5 В
Source Driver Voltage(Min)13.7 В
Special FunctionReset Generator
Target Application13 to 21 inches,21 inches and above
TopologyBoost,Buck
Vin(Max)14 В
Vin(Min)9.5 В
  • Generation of a VCOM buffer input using PWM signal
    PDF, 439 Кб, Файл опубликован: 21 дек 2015
    In an LCD the backlight shines through the liquid crystal material and the voltage across the liquid crystal controls how much light shines through it. An active matrix LCD (AMLCD) contains many pixels arranged in a grid pattern. The voltage across each pixel is controlled individually so that high resolution images can be created. One terminal of every pixel is connected to a common plane. The v
  • Understanding Undervoltage Lockout in Power Devices (Rev. A)
    PDF, 90 Кб, Версия: A, Файл опубликован: 19 сен 2018
    Many integrated circuits include an undervoltage lockout (UVLO) function to disable the device at low supply voltages. Below the minimum supply voltage the function and performance of a device may be undefined making it impossible to predict system behavior. This application note explains how to correctly understand the undervoltage lockout specification in the data sheets of TI's power products.
  • Minimizing Ringing at the Switch Node of a Boost Converter
    PDF, 201 Кб, Файл опубликован: 15 сен 2006
    The application report explains how to use proper board layout and/or a snubber to reduce high-frequency ringing at the switch node of a boost converter.
  • Basic Calculation of a Boost Converter's Power Stage (Rev. C)
    PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
    This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed.
Серия: TPS65176 (2)
  • Semiconductors > Power Management > LCD/OLED Display Bias Solutions
На английском языке: Datasheet Texas Instruments TPS65176RHDR
