Datasheet Texas Instruments TPS65177ARHAR — Даташит
СерияTPS65177A
МодельTPS65177ARHAR
Полностью программируемая 6-канальная ИС смещения ЖК-дисплея I2C для телевизоров всех размеров, включая Gate 40-VQFN -40 до 150
TPS65177/A Fully I2C Programmable 6-CH LCD Bias IC for all Size TV Including Gate Pulse Modulation datasheet
PDF, 3.5 Мб, Версия: C, Файл опубликован: 17 фев 2016
Pin40
Package TypeRHA
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY2500
Width (мм)6
Length (мм)6
Thickness (мм)0.9
Pitch (мм)0.5
Max Height (мм)1
DisplayTypeLCD Unipolar
IC IntegrationLCD Bias
Pin/Package40VQFN
Source Driver Voltage(Max)19.8 В
Source Driver Voltage(Min)13.5 В
Special FunctionGPM/GVS,HAVDD,I2C I/F,Temperature Sensor/Compensation
Target Application13 to 21 inches,21 inches and above
TopologyBoost,Buck
Vin(Max)14.7 В
Vin(Min)8.6 В
  • Understanding Undervoltage Lockout in Power Devices (Rev. A)
    PDF, 90 Кб, Версия: A, Файл опубликован: 19 сен 2018
    Many integrated circuits include an undervoltage lockout (UVLO) function to disable the device at low supply voltages. Below the minimum supply voltage the function and performance of a device may be undefined making it impossible to predict system behavior. This application note explains how to correctly understand the undervoltage lockout specification in the data sheets of TI's power products.
  • Minimizing Ringing at the Switch Node of a Boost Converter
    PDF, 201 Кб, Файл опубликован: 15 сен 2006
    The application report explains how to use proper board layout and/or a snubber to reduce high-frequency ringing at the switch node of a boost converter.
  • Basic Calculation of a Boost Converter's Power Stage (Rev. C)
    PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
    This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed.
Серия: TPS65177A (1)
  • TPS65177ARHAR
  • Semiconductors > Power Management > LCD/OLED Display Bias Solutions
На английском языке: Datasheet Texas Instruments TPS65177ARHAR
