Datasheet Texas Instruments TPS65177RHAR — Даташит
СерияTPS65177
МодельTPS65177RHAR
Fully IВІC programmable 6-Ch LCD Bias IC for all size TVs including Gate Pulse Modulation 40-VQFN -40 to 85
TPS65177/A Fully I2C Programmable 6-CH LCD Bias IC for all Size TV Including Gate Pulse Modulation datasheet
PDF, 3.5 Мб, Версия: C, Файл опубликован: 17 фев 2016
14 предложений от 14 поставщиков
Микросхема Чип управления батареи, Fully I²C programmable 6CH LCD Bias IC for all size TVs including Gate Pulse Modulation 40-VQFN -40℃...
TPS65177RHAR
67 ₽
Рутоника
TPS65177RHAR
216 ₽
ТаймЧипс
TPS65177RHAR
Hi-Tech Circuit Group
TPS65177RHAR
Pin40
Package TypeRHA
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY2500
Width (мм)6
Length (мм)6
Thickness (мм)0.9
Pitch (мм)0.5
Max Height (мм)1
Рекомендуемая замена
ReplacementTPS65177ARHAR
Replacement CodeF
  • Generation of a VCOM buffer input using PWM signal
    PDF, 439 Кб, Файл опубликован: 21 дек 2015
    In an LCD the backlight shines through the liquid crystal material and the voltage across the liquid crystal controls how much light shines through it. An active matrix LCD (AMLCD) contains many pixels arranged in a grid pattern. The voltage across each pixel is controlled individually so that high resolution images can be created. One terminal of every pixel is connected to a common plane. The v
  • Understanding Undervoltage Lockout in Power Devices (Rev. A)
    PDF, 90 Кб, Версия: A, Файл опубликован: 19 сен 2018
    Many integrated circuits include an undervoltage lockout (UVLO) function to disable the device at low supply voltages. Below the minimum supply voltage the function and performance of a device may be undefined making it impossible to predict system behavior. This application note explains how to correctly understand the undervoltage lockout specification in the data sheets of TI's power products.
  • Minimizing Ringing at the Switch Node of a Boost Converter
    PDF, 201 Кб, Файл опубликован: 15 сен 2006
    The application report explains how to use proper board layout and/or a snubber to reduce high-frequency ringing at the switch node of a boost converter.
  • Basic Calculation of a Boost Converter's Power Stage (Rev. C)
    PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
    This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed.
Серия: TPS65177 (1)
  • TPS65177RHAR
  • Semiconductors > Power Management > LCD/OLED Display Bias Solutions
На английском языке: Datasheet Texas Instruments TPS65177RHAR
