Datasheet Texas Instruments TPS65185RGZT — Даташит
| Серия | TPS65185 |
| Модель | TPS65185RGZT |
PMIC для дисплея на электронной бумаге с поддержкой E-Ink® Vizplex™ и активным разрядом 48-VQFN -40 to 85
TPS65185x PMIC for E Ink Vizplex Enabled   Electronic Paper Display datasheet
PDF, 3.0 Мб, Версия: G, Файл опубликован: 21 сен 2017
 Купить TPS65185RGZT на РадиоЛоцман.Цены — от 113 до 705 ₽31 предложений от 15 поставщиков Микросхема Управление питанием, PMIC for E-Ink® VizplexTM Enabled Electronic Paper Display, with Active Discharge 48-VQFN -40℃ to 85℃  | |||
| TPS65185RGZT Texas Instruments  | 149 ₽ | ||
| TPS65185RGZT Texas Instruments  | 432 ₽ | ||
| TPS65185RGZT Texas Instruments  | от 662 ₽ | ||
| TPS65185RGZT Texas Instruments  | по запросу | ||
| Pin | 48 |
| Package Type | RGZ |
| Industry STD Term | VQFN |
| JEDEC Code | S-PQFP-N |
| Package QTY | 250 |
| Carrier | SMALL T&R |
| Width (мм) | 7 |
| Length (мм) | 7 |
| Thickness (мм) | 0.9 |
| Pitch (мм) | 0.5 |
| Max Height (мм) | 1 |
| Mechanical Data | Скачать |
| DisplayType | eInk |
| IC Integration | eInk Bias |
| Pin/Package | 48VQFN, 48VQFN |
| Special Function | N/A |
| Target Application | N/A |
| Topology | N/A |
| Vin(Max) | 5.9 В |
| Vin(Min) | 3 В |
- Evaluation Modules & Boards: TPS65185EVM
TPS65185EVM
- Understanding Undervoltage Lockout in Power Devices (Rev. A)PDF, 90 Кб, Версия: A, Файл опубликован: 19 сен 2018
Many integrated circuits include an undervoltage lockout (UVLO) function to disable the device at low supply voltages. Below the minimum supply voltage the function and performance of a device may be undefined making it impossible to predict system behavior. This application note explains how to correctly understand the undervoltage lockout specification in the data sheets of TI's power products.
Серия: TPS65185 (7)
- Semiconductors > Power Management > LCD/OLED Display Bias Solutions
