Datasheet Texas Instruments TPS65185SRGZR — Даташит
СерияTPS65185
МодельTPS65185SRGZR
PMIC для дисплея на электронной бумаге с поддержкой E-Ink® Vizplex™ и активным разрядом 48-VQFN -40 to 85
TPS65185x PMIC for E Ink Vizplex Enabled Electronic Paper Display datasheet
PDF, 3.0 Мб, Версия: G, Файл опубликован: 21 сен 2017
Pin48
Package TypeRGZ
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY2500
Width (мм)7
Length (мм)7
Thickness (мм)0.9
Pitch (мм)0.5
Max Height (мм)1
DisplayTypeeInk
IC IntegrationeInk Bias
Pin/Package48VQFN, 48VQFN
Special FunctionN/A
Target ApplicationN/A
TopologyN/A
Vin(Max)5.9 В
Vin(Min)3 В
  • Evaluation Modules & Boards: TPS65185EVM
    TPS65185EVM
  • Understanding Undervoltage Lockout in Power Devices (Rev. A)
    PDF, 90 Кб, Версия: A, Файл опубликован: 19 сен 2018
    Many integrated circuits include an undervoltage lockout (UVLO) function to disable the device at low supply voltages. Below the minimum supply voltage the function and performance of a device may be undefined making it impossible to predict system behavior. This application note explains how to correctly understand the undervoltage lockout specification in the data sheets of TI's power products.
  • Semiconductors > Power Management > LCD/OLED Display Bias Solutions
На английском языке: Datasheet Texas Instruments TPS65185SRGZR
