Datasheet Texas Instruments TPS65190RHDR — Даташит
СерияTPS65190
МодельTPS65190RHDR
10-Channel Level Shifter for LCD DisplaysВ w/ VCOM Op-Amp 28-VQFN -40 to 85
10-Channel Level Shifter and VCOM Buffer for LCD Displays datasheet
PDF, 821 Кб, Файл опубликован: 8 сен 2009
Pin28
Package TypeRHD
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY3000
Width (мм)5
Length (мм)5
Thickness (мм)0.9
Pitch (мм)0.5
Max Height (мм)1
DisplayTypeN/A
IC IntegrationLCD Level shifter,VCOM
Level Shifter/Scan Driver10 Ch
Pin/Package28VQFN
Special FunctionVCOM/OpAmp
Target Application13 to 21 inches,21 inches and above
TopologyN/A
  • Understanding Undervoltage Lockout in Power Devices (Rev. A)
    PDF, 90 Кб, Версия: A, Файл опубликован: 19 сен 2018
    Many integrated circuits include an undervoltage lockout (UVLO) function to disable the device at low supply voltages. Below the minimum supply voltage the function and performance of a device may be undefined making it impossible to predict system behavior. This application note explains how to correctly understand the undervoltage lockout specification in the data sheets of TI's power products.
Серия: TPS65190 (1)
  • TPS65190RHDR
  • Semiconductors > Power Management > LCD/OLED Display Bias Solutions
На английском языке: Datasheet Texas Instruments TPS65190RHDR
