Datasheet Texas Instruments TPS65191RHBR — Даташит
СерияTPS65191
МодельTPS65191RHBR
7-Channel Level Shifter for LCD DisplaysВ (Triple Channel Scan Driver) 32-VQFN -40 to 85
Triple High-Voltage Scan Driver for TFT-LCD datasheet
PDF, 2.4 Мб, Версия: A, Файл опубликован: 2 авг 2010
Интегральные микросхемы Линейные микросхемы - Микросхемы обработки видеоинформации
TPS65191RHBR
87 ₽
TPS65191RHBR
121 ₽
TPS65191RHBR
от 277 ₽
Зенер
Россия и страны ТС
TPS65191RHBR
от 302 ₽
Pin32
Package TypeRHB
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY3000
Width (мм)5
Length (мм)5
Thickness (мм)0.9
Pitch (мм)0.5
Max Height (мм)1
DisplayTypeLCD Bipolar,LCD Unipolar
IC IntegrationLCD Level shifter
Level Shifter/Scan Driver7 Ch
Pin/Package32VQFN
Special FunctionCharge Sharing
Target Application13 to 21 inches,21 inches and above
TopologyN/A
  • Understanding Undervoltage Lockout in Power Devices (Rev. A)
    PDF, 90 Кб, Версия: A, Файл опубликован: 19 сен 2018
    Many integrated circuits include an undervoltage lockout (UVLO) function to disable the device at low supply voltages. Below the minimum supply voltage the function and performance of a device may be undefined making it impossible to predict system behavior. This application note explains how to correctly understand the undervoltage lockout specification in the data sheets of TI's power products.
Серия: TPS65191 (1)
  • TPS65191RHBR
  • Semiconductors > Power Management > LCD/OLED Display Bias Solutions
На английском языке: Datasheet Texas Instruments TPS65191RHBR
