Datasheet Texas Instruments TPS65192RHDR — Даташит
| Серия | TPS65192 |
| Модель | TPS65192RHDR |
9-Channel Level Shifter for LCD DisplaysВ with GPM 28-VQFN -40 to 85
9 Channel Level Shifter with Gate Voltage Shaping and Discharge Functions datasheet
PDF, 1.9 Мб, Файл опубликован: 15 июл 2009
Купить TPS65192RHDR на РадиоЛоцман.Цены — от 33 до 390 ₽22 предложений от 16 поставщиков Интегральные микросхемы Линейные микросхемы - Микросхемы обработки видеоинформации | |||
| TPS65192RHDR Texas Instruments | 69 ₽ | ||
| TPS65192RHDR Texas Instruments | 102 ₽ | ||
| TPS65192RHDR Texas Instruments | 217 ₽ | ||
| TPS65192RHDR Texas Instruments | по запросу | ||
| Pin | 28 |
| Package Type | RHD |
| Industry STD Term | VQFN |
| JEDEC Code | S-PQFP-N |
| Package QTY | 3000 |
| Carrier | LARGE T&R |
| Width (мм) | 5 |
| Length (мм) | 5 |
| Thickness (мм) | 0.9 |
| Pitch (мм) | 0.5 |
| Max Height (мм) | 1 |
| Mechanical Data | Скачать |
| DisplayType | LCD Bipolar,LCD Unipolar |
| IC Integration | LCD Level shifter |
| Level Shifter/Scan Driver | 9 Ch |
| Pin/Package | 28VQFN |
| Special Function | GPM/GVS,Output Discharge |
| Target Application | 13 to 21 inches,21 inches and above |
| Topology | N/A |
- TPS6519x Power Dissipation Estimation in Typical Level Shifter ApplicationPDF, 138 Кб, Файл опубликован: 8 дек 2015
The power dissipation in a LCD gate-driving circuit is shared between the level shifter output stages and the parasitic components in the display. The dynamic characteristics of the level shifter output stage and the parasitic component values are frequently unavailable. Thus it is often difficult to estimate the power dissipation. This application note presents a method to evaluate the power diss - Understanding Undervoltage Lockout in Power Devices (Rev. A)PDF, 90 Кб, Версия: A, Файл опубликован: 19 сен 2018
Many integrated circuits include an undervoltage lockout (UVLO) function to disable the device at low supply voltages. Below the minimum supply voltage the function and performance of a device may be undefined making it impossible to predict system behavior. This application note explains how to correctly understand the undervoltage lockout specification in the data sheets of TI's power products.
Серия: TPS65192 (1)
- TPS65192RHDR
- Semiconductors > Power Management > LCD/OLED Display Bias Solutions
