Datasheet Texas Instruments TPS65194RGER — Даташит
СерияTPS65194
МодельTPS65194RGER
13-канальный преобразователь уровня сигнала для ЖК-телевизоров и мониторов 24-VQFN -40 to 85
TPS65194 Features datasheet
PDF, 1.6 Мб, Файл опубликован: 25 авг 2010
Pin24
Package TypeRGE
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY3000
Width (мм)4
Length (мм)4
Thickness (мм)0.88
Pitch (мм)0.5
Max Height (мм)1
DisplayTypeLCD Bipolar,LCD Unipolar
IC IntegrationLCD Level shifter
Level Shifter/Scan Driver13 Ch
Pin/Package24VQFN
Special FunctionGPM/GVS,Output Discharge
Target Application13 to 21 inches,21 inches and above
TopologyN/A
  • Understanding Undervoltage Lockout in Power Devices (Rev. A)
    PDF, 90 Кб, Версия: A, Файл опубликован: 19 сен 2018
    Many integrated circuits include an undervoltage lockout (UVLO) function to disable the device at low supply voltages. Below the minimum supply voltage the function and performance of a device may be undefined making it impossible to predict system behavior. This application note explains how to correctly understand the undervoltage lockout specification in the data sheets of TI's power products.
Серия: TPS65194 (1)
  • TPS65194RGER
  • Semiconductors > Power Management > LCD/OLED Display Bias Solutions
На английском языке: Datasheet Texas Instruments TPS65194RGER
