Datasheet Texas Instruments TPS65197RUYR — Даташит
СерияTPS65197
МодельTPS65197RUYR
8-канальный преобразователь уровня, поддерживающий 2-, 3-канальное разделение заряда и разрядку панели 28-WQFN -40 to 85
TPS65197x: 8-Channel Level-Shifter Supporting No, 2-Channel and 3-Channel Charge-Sharing with Panel Discharge to VGH during Shut-Down datasheet
PDF, 1.5 Мб, Версия: D, Файл опубликован: 12 фев 2018
Pin28
Package TypeRUY
Industry STD TermWQFN
JEDEC CodeS-PQFP-N
Package QTY3000
Width (мм)4
Length (мм)4
Thickness (мм)0.75
Pitch (мм)0.4
Max Height (мм)0.8
DisplayTypeLCD Bipolar,LCD Unipolar
Level Shifter/Scan Driver8 Ch
Pin/Package28WQFN
Special FunctionCharge Sharing,Output Discharge
Target Application13 to 21 inches,21 inches and above
TopologyN/A
  • Understanding Undervoltage Lockout in Power Devices (Rev. A)
    PDF, 90 Кб, Версия: A, Файл опубликован: 19 сен 2018
    Many integrated circuits include an undervoltage lockout (UVLO) function to disable the device at low supply voltages. Below the minimum supply voltage the function and performance of a device may be undefined making it impossible to predict system behavior. This application note explains how to correctly understand the undervoltage lockout specification in the data sheets of TI's power products.
Серия: TPS65197 (3)
  • Semiconductors > Power Management > LCD/OLED Display Bias Solutions
На английском языке: Datasheet Texas Instruments TPS65197RUYR
