Datasheet Texas Instruments TPS65198RUYT — Даташит
| Серия | TPS65198 |
| Модель | TPS65198RUYT |
13-канальный преобразователь уровня с операционным усилителем для ЖК-телевизоров и мониторов 28-WQFN -40 to 85
Купить TPS65198RUYT на РадиоЛоцман.Цены — от 23 до 519 ₽38 предложений от 16 поставщиков Интегральные микросхемы Линейные микросхемы - Микросхемы обработки видеоинформации | |||
| TPS65198RUYT Texas Instruments | 58 ₽ | ||
| TPS65198RUYT Texas Instruments | 79 ₽ | ||
| TPS65198RUYT Texas Instruments | по запросу | ||
| Pin | 28 |
| Package Type | RUY |
| Industry STD Term | WQFN |
| JEDEC Code | S-PQFP-N |
| Package QTY | 250 |
| Carrier | SMALL T&R |
| Width (мм) | 4 |
| Length (мм) | 4 |
| Thickness (мм) | 0.75 |
| Pitch (мм) | 0.4 |
| Max Height (мм) | 0.8 |
| Mechanical Data | Скачать |
| DisplayType | N/A |
| IC Integration | LCD Level shifter,VCOM |
| Level Shifter/Scan Driver | 13 Ch |
| Pin/Package | 28WQFN |
| Special Function | GPM/GVS,VCOM/OpAmp |
| Target Application | 13 to 21 inches,21 inches and above |
| Topology | N/A |
- TPS6519x Power Dissipation Estimation in Typical Level Shifter ApplicationPDF, 138 Кб, Файл опубликован: 8 дек 2015
The power dissipation in a LCD gate-driving circuit is shared between the level shifter output stages and the parasitic components in the display. The dynamic characteristics of the level shifter output stage and the parasitic component values are frequently unavailable. Thus it is often difficult to estimate the power dissipation. This application note presents a method to evaluate the power diss - Understanding Undervoltage Lockout in Power Devices (Rev. A)PDF, 90 Кб, Версия: A, Файл опубликован: 19 сен 2018
Many integrated circuits include an undervoltage lockout (UVLO) function to disable the device at low supply voltages. Below the minimum supply voltage the function and performance of a device may be undefined making it impossible to predict system behavior. This application note explains how to correctly understand the undervoltage lockout specification in the data sheets of TI's power products.
Серия: TPS65198 (2)
- TPS65198RUYR TPS65198RUYT
- Semiconductors > Power Management > LCD/OLED Display Bias Solutions
