Datasheet Texas Instruments TPS65235-1RUKR — Даташит
СерияTPS65235-1
МодельTPS65235-1RUKR
Регулятор напряжения LNB с интерфейсом I2C 20-WQFN от -40 до 85
TPS65235-1 LNB Voltage Regulator With I2C Interface datasheet
PDF, 2.4 Мб, Версия: A, Файл опубликован: 5 дек 2017
Pin20
Package TypeRUK
Industry STD TermWQFN
JEDEC CodeS-PQFP-N
Package QTY3000
Width (мм)3
Length (мм)3
Thickness (мм)0.75
Pitch (мм)0.4
Max Height (мм)0.8
Duty Cycle(Max)77.5 %
Основные особенностиAdjustable Current Limit,I2C,Power Good
Iout(Max)1 A
Iq(Typ)0.12 мА
Package GroupWQFN
Regulated Outputs1
Switch Current Limit(Min)2.4 A
Switch Current Limit(Typ)3 A
Switching Frequency(Max)1000 kHz
Switching Frequency(Min)500 kHz
ТипConverter
Vin(Max)16 В
Vin(Min)4.5 В
Vout(Max)20 В
Vout(Min)11 В
  • Evaluation Modules & Boards: TPS65235-1EVM-694
    TPS65235-1 LNB Voltage Regulator With I2C Interface Evaluation Module
  • Evaluation Modules & Boards: TPS65235-1EVM-747
  • Introduction to Anti-Audible Noise Function in TPS65235-1
    PDF, 717 Кб, Файл опубликован: 13 ноя 2017
    The TPS65235-1 implements an anti-audible noise function to eliminate the audible noise in forced continuous conduction mode (FCCM). This application note introduces this anti-audible noise function which includes the root cause of audible noise the circuit modifications in design and the EVM laboratory validation. In addition the BOOST converter output filter capacitor and
Серия: TPS65235-1 (2)
  • Semiconductors > Power Management > DC/DC Switching Regulator > Step-Up (Boost) > Boost Converter (Integrated Switch)
TPS652351RUKR, TPS65235 1RUKR
На английском языке: Datasheet Texas Instruments TPS65235-1RUKR
