Datasheet Texas Instruments TPS65631DPDR — Даташит
СерияTPS65631
МодельTPS65631DPDR
Блок питания для дисплея AMOLED с двумя выходами 12-WSON -40 to 85
TPS65631 Dual-Output AMOLED Display Power Supply datasheet
PDF, 1.1 Мб, Версия: E, Файл опубликован: 14 май 2014
22 предложений от 15 поставщиков
Интегральные микросхемы Микросхемы управления электропитанием - Стабилизаторы напряжения - Специальное назначение
TPS65631DPDR
39 ₽
Эиком
TPS65631DPDR
от 317 ₽
727GS
TPS65631DPDR
МосЧип
TPS65631DPDR
Pin12
Package TypeDPD
Industry STD TermWSON
JEDEC CodeS-PSSO-N
Package QTY3000
Width (мм)3
Length (мм)3
Thickness (мм)0.7
Pitch (мм)0.45
Max Height (мм)0.8
DisplayTypeAMOLED
IC IntegrationAMOLED Bias
Pin/Package12WSON
Special FunctionDigital Control I/F
Target Application7 inches or less
TopologyBoost,Buck-Boost
V_NEG(Max)-1.4 В
V_NEG(Min)-4.4 В
V_POS(Max)4.6 В
V_POS(Min)4.6 В
Vin(Max)4.5 В
Vin(Min)2.9 В
  • Basic Calculation of an Inverting Buck-Boost Power Stage (Rev. A)
    PDF, 431 Кб, Версия: A, Файл опубликован: 28 авг 2017
    This application note provides basic formulas that you need to design the power stage of an invertingbuck-boost converter. The premise is that the power switch is integrated in the IC and the rectification isdone by a diode (non-synchronous power stage). It provides all the formulas and considerations that youneed to select the external power components such as the inductor the diode and t
  • Understanding Undervoltage Lockout in Power Devices (Rev. A)
    PDF, 90 Кб, Версия: A, Файл опубликован: 19 сен 2018
    Many integrated circuits include an undervoltage lockout (UVLO) function to disable the device at low supply voltages. Below the minimum supply voltage the function and performance of a device may be undefined making it impossible to predict system behavior. This application note explains how to correctly understand the undervoltage lockout specification in the data sheets of TI's power products.
  • Minimizing Ringing at the Switch Node of a Boost Converter
    PDF, 201 Кб, Файл опубликован: 15 сен 2006
    The application report explains how to use proper board layout and/or a snubber to reduce high-frequency ringing at the switch node of a boost converter.
  • Basic Calculation of a Boost Converter's Power Stage (Rev. C)
    PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
    This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed.
Серия: TPS65631 (1)
  • TPS65631DPDR
  • Semiconductors > Power Management > LCD/OLED Display Bias Solutions
На английском языке: Datasheet Texas Instruments TPS65631DPDR
