Datasheet Texas Instruments TPS65640RHRR — Даташит
СерияTPS65640
МодельTPS65640RHRR
ЖК-дисплей Bias с цифровым буфером VCOM для ноутбуков и планшетных ПК 28-WQFN -40 до 85
LCD Bias with Digital-VCOM Buffer for Notebook PCs and Tablet PCs datasheet
PDF, 728 Кб, Версия: A, Файл опубликован: 15 ноя 2013
IC REG CONV TFT LCD 5OUT 28WQFN. - Converter, TFT LCD Voltage Regulator IC 5 Output 28-WQFN (5.5x3.5). PMIC - Voltage...
TPS65640RHRR
102 ₽
TPS65640RHRR
364 ₽
TPS65640RHRR
373 ₽
Hi-Tech Circuit Group
TPS65640RHRR
Pin28
Package TypeRHR
Industry STD TermWQFN
JEDEC CodeR-PQFP-N
Package QTY3000
Width (мм)3.5
Length (мм)5.5
Thickness (мм)0.75
Pitch (мм)0.5
Max Height (мм)0.8
DisplayTypeLCD Bipolar,LCD Unipolar
IC IntegrationLCD Bias,VCOM
Pin/Package28WQFN
Source Driver Voltage(Max)12.7 В
Source Driver Voltage(Min)-8 В
Special FunctionAdjustable Sequencing,GPM/GVS,I2C I/F,Output Discharge,Reset Generator,Temperature Sensor/Compensation,VCOM/OpAmp
Target Application13 to 21 inches,7 to 13 inches
TopologyN/A
Vin(Max)2.5 В
Vin(Min)-3.8 В
  • Understanding Undervoltage Lockout in Power Devices (Rev. A)
    PDF, 90 Кб, Версия: A, Файл опубликован: 19 сен 2018
    Many integrated circuits include an undervoltage lockout (UVLO) function to disable the device at low supply voltages. Below the minimum supply voltage the function and performance of a device may be undefined making it impossible to predict system behavior. This application note explains how to correctly understand the undervoltage lockout specification in the data sheets of TI's power products.
  • Minimizing Ringing at the Switch Node of a Boost Converter
    PDF, 201 Кб, Файл опубликован: 15 сен 2006
    The application report explains how to use proper board layout and/or a snubber to reduce high-frequency ringing at the switch node of a boost converter.
  • Basic Calculation of a Boost Converter's Power Stage (Rev. C)
    PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
    This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed.
Серия: TPS65640 (1)
  • TPS65640RHRR
  • Semiconductors > Power Management > LCD/OLED Display Bias Solutions
На английском языке: Datasheet Texas Instruments TPS65640RHRR
