Datasheet Texas Instruments INA106U — Даташит
СерияINA106
МодельINA106U
Прецизионный дифференциальный усилитель с фиксированным коэффициентом усиления 8-SOIC
INA106: Precision Gain = 10 Differential Amplifier datasheet
PDF, 1.5 Мб, Версия: A, Файл опубликован: 7 окт 2003
Pin88
Package TypeDD
Industry STD TermSOICSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY7575
CarrierTUBETUBE
МаркировкаINA106U
Width (мм)3.913.91
Length (мм)4.94.9
Thickness (мм)1.581.58
Pitch (мм)1.271.27
Max Height (мм)1.751.75
CMRR(Min)86 дБ
Common Mode Input High(Max)11 В
Common Mode Input High(Min)11 В
Common Mode Input Low(Min)-11 В
Gain10 V/V
Gain Drift(Max)4 ppm/C
Gain Error (+/-)(Max)0.025 %
Gain(Max)10 V/V
Gain(Min)10 V/V
Input Offset (+/-)(Max)200 uV
Iq(Typ)1.5 мА
Количество каналов1
Slew Rate(Typ)3 V/us
Small Signal Bandwidth(Typ)5 МГц
Vs(Max)36 В
Vs(Min)10 В
  • Boost Amplifier Output Swing With Simple Modification
    PDF, 46 Кб, Файл опубликован: 27 сен 2000
    In many applications it is desirable for the output of an amplifier to swing close to its power supply rails. Most amplifiers only guarantee an output swing of В±10V to В±12V when operating on standard В±15V power supplies. With the addition of four resistors and a pair of garden-variety transistors, the INA105 or INA106 difference amplifiers can be modified to provide nearly a f
  • Boost Instrument Amp CMR With Common-Mode Driven Supplies
    PDF, 175 Кб, Файл опубликован: 27 сен 2000
    Ever-increasing demands are being placed on instrumentation amplifier (IA) performance. When standard IAs can not deliver the required performance, consider this enhanced version. Dramatic performance improvements can be achieved by operating the input amplifiers of a classical three-op-amp IA from common-mode driven sub-regulated power supplies.
  • AC Coupling Instrumentation and Difference Amplifiers
    PDF, 38 Кб, Файл опубликован: 27 сен 2000
    The need to glean AC signals from DC in the presence of common-mode noise frequently occurs in signal conditioning applications. AC coupling to an instrumentation amplifier (IA) or difference amplifier can be used to accurately extract the AC signal while rejecting DC and common-mode noise.
  • Implementation and Applications of Current Sources and Current Receivers
    PDF, 427 Кб, Файл опубликован: 27 сен 2000
    This application guide is intended as a source book for the design and application of: Current sourcesCurrent sinksFloating current sourcesVoltage-to-current converters(transconductance amplifiers)Current-to-current converters (current mirrors)Current-to-voltage converters(transimpedance amplifiers)
  • Semiconductors > Amplifiers > Difference Amplifiers
На английском языке: Datasheet Texas Instruments INA106U
