Datasheet Texas Instruments INA117KU — Даташит
СерияINA117
МодельINA117KU
Усилитель разницы синфазных напряжений с высоким синфазным напряжением 8-SOIC от -40 до 85
INA117: High Common-Mode Voltage Difference Amplifier datasheet
PDF, 312 Кб, Версия: A, Файл опубликован: 26 ноя 2000
Pin888
Package TypeDDD
Industry STD TermSOICSOICSOIC
Package QTY757575
CarrierTUBETUBETUBE
МаркировкаINA117KU2
Width (мм)3.913.913.91
Length (мм)4.94.94.9
Thickness (мм)1.581.581.58
Pitch (мм)1.271.271.27
Max Height (мм)1.751.751.75
CMRR(Min)86 дБ
Common Mode Input High(Max)200 В
Common Mode Input High(Min)200 В
Common Mode Input Low(Min)-200 В
Gain1 V/V
Gain Drift(Max)10 ppm/C
Gain Error (+/-)(Max)0.05 %
Gain(Max)1 V/V
Gain(Min)1 V/V
Input Offset (+/-)(Max)1000 uV
Iq(Typ)2 мА
Количество каналов1
Slew Rate(Typ)2.6 V/us
Small Signal Bandwidth(Typ)0.2 МГц
Vs(Max)36 В
Vs(Min)10 В
  • Input Filtering The INA117 В±200V Difference Amplifier
    PDF, 48 Кб, Файл опубликован: 27 сен 2000
    Many customers have asked how to add input filtering to the INA117. Since the INA117 is rated for В±200V input voltage (В±500V without damage), it is commonly used in environments with very high input noise or with high-voltage input transients. This bulletin shows how to connect input filters, discusses the errors they can add, and shows how to eliminate the errors.
  • В±200V Difference Amplifier with Common-Mode Voltage Monitor
    PDF, 32 Кб, Файл опубликован: 27 сен 2000
    The INA117 is a monolithic difference amplifier with the unique ability to accept up to В±200V common-mode input signals while operating on standard В±15V power supplies. Using on-chip high-voltage resistor dividers, the INA117 rejects common-mode signals up to В±200V and translates a 0V to В±10V differential input signal to a 0V to В±10V ground-referenced output sign
  • Increasing INA117 Differential Input Range
    PDF, 30 Кб, Файл опубликован: 27 сен 2000
    The INA117 is a monolithic difference amplifier with the unique ability to accept up to В±200V common-mode input signals while operating on standard В±15V power supplies. Because the gain of the INA117 is set at 1V/V, and because the output would saturate into the rails at about В±12V, the maximum specified differential input range is В±10V.
  • Extending the Common-Mode Range of Difference Amplifiers
    PDF, 49 Кб, Файл опубликован: 27 сен 2000
    Extending the common-mode range of difference amplifiers allows their use in a wider variety of reduced power-supply applications. The INA117 has a specified common-mode input range of В±200V when operating on standard В±15V power supplies. At power-supply voltages above В±13V, the INA117 input range is limited to В±200V by the power capabilities of its internal input resis
  • AC Coupling Instrumentation and Difference Amplifiers
    PDF, 38 Кб, Файл опубликован: 27 сен 2000
    The need to glean AC signals from DC in the presence of common-mode noise frequently occurs in signal conditioning applications. AC coupling to an instrumentation amplifier (IA) or difference amplifier can be used to accurately extract the AC signal while rejecting DC and common-mode noise.
  • Implementation and Applications of Current Sources and Current Receivers
    PDF, 427 Кб, Файл опубликован: 27 сен 2000
    This application guide is intended as a source book for the design and application of: Current sourcesCurrent sinksFloating current sourcesVoltage-to-current converters(transconductance amplifiers)Current-to-current converters (current mirrors)Current-to-voltage converters(transimpedance amplifiers)
  • Offset Correction Methods: Laser Trim, e-Trim, and Chopper (Rev. A)
    PDF, 795 Кб, Версия: A, Файл опубликован: 20 июл 2017
  • Semiconductors > Amplifiers > Difference Amplifiers
На английском языке: Datasheet Texas Instruments INA117KU
