Datasheet Texas Instruments TSB12LV01BPZT — Даташит
Серия | TSB12LV01B |
Модель | TSB12LV01BPZT |
High Performance 1394 3.3V Link Layer for Telecom, Embedded & Industrial App.,32-Bit I/F, 2kb FIFO 100-TQFP 0 to 70
TSB12LV01B IEEE 1394-1995 High-Speed Serial-Link-Layer Controller datasheet
PDF, 84 Кб, Файл опубликован: 24 май 2006
Купить TSB12LV01BPZT на РадиоЛоцман.Цены — от 140 до 3 241 ₽ 21 предложений от 14 поставщиков High Performance 1394 3.3V Link Layer for Telecom, Embedded & Industrial App.,32Bit I/F, 2KB FIFO_x0000__x0000_ | |||
TSB12LV01BPZT Texas Instruments | от 140 ₽ | ||
TSB12LV01BPZT Texas Instruments | 867 ₽ | ||
TSB12LV01BPZT Texas Instruments | 913 ₽ | ||
TSB12LV01BPZT | по запросу |
Pin | 100 | 100 |
Package Type | PZT | PZT |
Industry STD Term | TQFP | TQFP |
JEDEC Code | S-PQFP-G | S-PQFP-G |
Package QTY | 90 | 90 |
Carrier | JEDEC TRAY (10+1) | JEDEC TRAY (10+1) |
Маркировка | TSB12LV01B | F711934 |
Width (мм) | 14 | 14 |
Length (мм) | 14 | 14 |
Thickness (мм) | 1 | 1 |
Pitch (мм) | .5 | .5 |
Max Height (мм) | 1.2 | 1.2 |
Рабочий диапазон температур | от -40 до 85,0 до 70 C |
Package Group | TQFP |
Package Size: mm2:W x L | 100TQFP: 256 mm2: 16 x 16(TQFP) PKG |
Rating | Catalog |
- TSB12LV01B/TSB41AB3 Reference Schematic (Rev. A)PDF, 98 Кб, Версия: A, Файл опубликован: 23 янв 2001
This application report describes the electrical connections between the Texas Instruments TSB12LV01B and TSB41AB3 for common modes of operation. Use this document in conjunction with the TI application report, Recommendations for PHY Layout (SLLA020), to successfully design a 1394 system.The TSB12LV01B is a high-performance, general-purpose IEEE 1394-1995 link-layer controller (LLC) with the - Interfacing Between the 1394a Links and TSB41BA3A (Rev. A)PDF, 134 Кб, Версия: A, Файл опубликован: 4 окт 2004
Серия: TSB12LV01B (3)
- TSB12LV01BIPZT TSB12LV01BPZT TSB12LV01BPZTG4
- Semiconductors > Interface > More Interfaces
