Datasheet Texas Instruments TSC2000IPWR — Даташит
СерияTSC2000
МодельTSC2000IPWR
4-проводной программируемый контроллер сенсорного экрана с 8/10/12-битным 125-кГц АЦП и интерфейсом SPI 20-TSSOP -40 до 85
TSC2000: PDA Analog Interface Circuit datasheet
PDF, 1.0 Мб, Файл опубликован: 30 янв 2002
Pin20
Package TypePW
Industry STD TermTSSOP
Package QTY2000
МаркировкаTSC2000I
Width (мм)4.4
Length (мм)6.5
Thickness (мм)1
Max Height (мм)1.2
Control InterfaceSPI
Тип входаSingle-Ended
Package GroupTSSOP
SAR ADC Resolution12 Bits
SAR Sample Rate(Max)125 kSPS
Supply Voltage (Analog)2.7 Max
Supply Voltage (I/O VDD)3.6 Min
Touch Panel4-Wire
VrefInt Int/Ext
  • Applying the Current DAC on the TSC2000, TSC2200, TSC2300, and TSC2301 Touch Scr
    PDF, 60 Кб, Файл опубликован: 13 июн 2003
    Applying the Current DAC on the TSC2000, TSC2200, TSC2300, and TSC2301 Touch Screen Controllers
  • Programming Sequences and Tips for TSC2000/2200/230x Applications
    PDF, 206 Кб, Файл опубликован: 8 мар 2004
    To apply the touchscreen function of a TSC2000, TSC2200, or TSC230x device, certain software programming sequences are crucial during the TSC initialization and data reading and are also helpful during the TSC mode changing. This application report presents some practical programming sequences. Additionally, some program and debug tips are provided.
  • Apply TI TSC for Various and Multiple Functions
    PDF, 316 Кб, Файл опубликован: 11 дек 2006
    This application report presents several examples showing how a touch screen controller (TSC) from Texas Instruments provides a variety of functions such as graphs, scroll bars, pressure buttons, and analog dials. A simple resistive TSC can be used to achieve all of these functions as long as they are not activated simultaneously. This application report demonstrates a few simple examples how th
Серия: TSC2000 (4)
  • Semiconductors > Data Converters > Integrated/Special Function Data Converters > Touch Screen Controllers
На английском языке: Datasheet Texas Instruments TSC2000IPWR
