Datasheet Texas Instruments TSC2000IPWRG4 — Даташит
Серия | TSC2000 |
Модель | TSC2000IPWRG4 |
4-проводной программируемый контроллер сенсорного экрана с 8/10/12-битным 125-кГц АЦП и интерфейсом SPI 20-TSSOP -40 до 85
TSC2000: PDA Analog Interface Circuit datasheet
PDF, 1.0 Мб, Файл опубликован: 30 янв 2002
Pin | 20 |
Package Type | PW |
Industry STD Term | TSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 2000 |
Carrier | LARGE T&R |
Маркировка | TSC2000I |
Width (мм) | 4.4 |
Length (мм) | 6.5 |
Thickness (мм) | 1 |
Pitch (мм) | .65 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
Control Interface | SPI |
Тип входа | Single-Ended |
Package Group | TSSOP |
Package Size: mm2:W x L | 20TSSOP: 42 mm2: 6.4 x 6.5(TSSOP) PKG |
Rating | Catalog |
SAR ADC Resolution | 12 Bits |
SAR Sample Rate(Max) | 125 kSPS |
Supply Voltage (Analog) | 2.7 Max |
Supply Voltage (I/O VDD) | 3.6 Min |
Touch Panel | 4-Wire |
Vref | Int Int/Ext |
- Applying the Current DAC on the TSC2000, TSC2200, TSC2300, and TSC2301 Touch ScrPDF, 60 Кб, Файл опубликован: 13 июн 2003
Applying the Current DAC on the TSC2000, TSC2200, TSC2300, and TSC2301 Touch Screen Controllers - Programming Sequences and Tips for TSC2000/2200/230x ApplicationsPDF, 206 Кб, Файл опубликован: 8 мар 2004
To apply the touchscreen function of a TSC2000, TSC2200, or TSC230x device, certain software programming sequences are crucial during the TSC initialization and data reading and are also helpful during the TSC mode changing. This application report presents some practical programming sequences. Additionally, some program and debug tips are provided. - Apply TI TSC for Various and Multiple FunctionsPDF, 316 Кб, Файл опубликован: 11 дек 2006
This application report presents several examples showing how a touch screen controller (TSC) from Texas Instruments provides a variety of functions such as graphs, scroll bars, pressure buttons, and analog dials. A simple resistive TSC can be used to achieve all of these functions as long as they are not activated simultaneously. This application report demonstrates a few simple examples how th
Серия: TSC2000 (4)
- TSC2000IPW TSC2000IPWG4 TSC2000IPWR TSC2000IPWRG4
- Semiconductors > Data Converters > Integrated/Special Function Data Converters > Touch Screen Controllers
