Datasheet Texas Instruments TSC2005IYZLT — Даташит
Серия | TSC2005 |
Модель | TSC2005IYZLT |
Контроллер сенсорного экрана Nano-Power с последовательным интерфейсом SPI 28-DSBGA -40 to 85
1.6V to 3.6V, 12-Bit, Nanopower, 4-Wire Touch Screen Controller w/SPIв„ў Interface datasheet
PDF, 1.4 Мб, Версия: C, Файл опубликован: 21 мар 2008
Pin | 28 |
Package Type | YZL |
Industry STD Term | DSBGA |
JEDEC Code | R-XBGA-N |
Package QTY | 250 |
Carrier | SMALL T&R |
Маркировка | TSC2005I |
Thickness (мм) | .65 |
Pitch (мм) | .5 |
Max Height (мм) | 1 |
Mechanical Data | Скачать |
- TSC2005 Power Consumption Under Different ModesPDF, 1.1 Мб, Файл опубликован: 12 окт 2007
This application report discusses the TSC2005 power consumption under different modes, addresses the function and power of various TSC2005 modes, and provides a guideline for using the TSC2005 to perform the required functions and features with the optimal low power consumption. - TSC2005/6 LinuxВ® DriversTSP, Файл опубликован: 29 мар 2009
This application report describes the TSC2005 and TSC2006 touch drivers for the LinuxВ® operating system to help customers to implement designs using the TSC2005 or the TSC2006 touch-screen controllers. It also discusses the drivers and associated code. The Linux driver code can be integrated into a customer's software system under different host processors. These drivers have been tested and us - POR and Resets in TSC2004/5/6PDF, 96 Кб, Файл опубликован: 16 окт 2011
The TSC2004, TSC2005, and TSC2006 are a series of nanopower, four-wire resistive touch screen controllers (TSCs), with either an IВІCв„ў (TSC2004) or SPIв„ў (TSC2005 or TSC2006) digital interface. To ensure that the TSCs power up at a known default working state, the proper power-on-reset (POR) requirements should be implemented. In addition to the POR option, the TSC2004/5/6 also feat - Important Considerations to Assure a Safe PORPDF, 115 Кб, Файл опубликован: 10 мар 2009
This application report explains specific and important considerations related to the automatic power-on reset feature of the TSC2007 touch-screen controller. It also discusses several possible issues that may arise as a result of improperly powering the device on or off, and provides application solutions to ensure proper TSC2007 operation under various power-supply conditions. - Set Up and Use TSC TimingsPDF, 271 Кб, Файл опубликован: 7 июн 2007
This application report helps users to understand, set up, and use the programming timings in the register-based touch screen controller (TSC) devices. It displays the timings functions and discusses the effect on the system interface traffic and on the system power consumption. - Q3 2007 Issue Analog Applications JournalPDF, 617 Кб, Файл опубликован: 10 авг 2007
- Using a touch-screen controller’s auxiliary inputsPDF, 149 Кб, Файл опубликован: 12 окт 2007
- PCB Layout Guideline for TI Resistive TSC DevicesPDF, 144 Кб, Файл опубликован: 4 окт 2012
- Operation Schemes of Touch Screen ControllersPDF, 846 Кб, Файл опубликован: 21 май 2007
- Reducing Analog Input Noise in Touch Screen Systems (Rev. A)PDF, 535 Кб, Версия: A, Файл опубликован: 15 сен 2007
This application report discusses some common methods for reducing noise in the analog input circuitry of a resistive touch screen controller. In terms of hardware design, PCB layout and grounding are critical; the additional noise-decoupling capacitor built into a touch screen controller input pin may also help. On the software side, several simple, widely-applied filtering algorithms are present - Calibration in touch-screen systemsPDF, 169 Кб, Файл опубликован: 10 авг 2007
- Q4 2007 Issue Analog Applications Journal (Rev. A)PDF, 316 Кб, Версия: A, Файл опубликован: 14 ноя 2007
- Apply TI TSC for Various and Multiple FunctionsPDF, 316 Кб, Файл опубликован: 11 дек 2006
This application report presents several examples showing how a touch screen controller (TSC) from Texas Instruments provides a variety of functions such as graphs, scroll bars, pressure buttons, and analog dials. A simple resistive TSC can be used to achieve all of these functions as long as they are not activated simultaneously. This application report demonstrates a few simple examples how th
Серия: TSC2005 (2)
- TSC2005IYZLR TSC2005IYZLT
- Semiconductors > Data Converters > Integrated/Special Function Data Converters > Touch Screen Controllers
