Datasheet Texas Instruments TSC2007IPW — Даташит
СерияTSC2007
МодельTSC2007IPW
Контроллер сенсорного экрана Nano-Power с последовательным интерфейсом I2C 16-TSSOP -40 to 85
Nano-Power Touch Screen Controller with IВІCв„ў Serial Interface datasheet
PDF, 1.3 Мб, Версия: A, Файл опубликован: 2 мар 2009
Pin16
Package TypePW
Industry STD TermTSSOP
Package QTY90
МаркировкаTSC2007
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
Control InterfaceI2C
Тип входаDifferential,Single-Ended
Package GroupTSSOP
Package Size: mm2:W x L16TSSOP: 32 mm2: 6.4 x 5(TSSOP) PKG
SAR ADC Resolution12 Bits
SAR Sample Rate(Max)154 kSPS
Supply Voltage (Analog)1.2 Max
Supply Voltage (I/O VDD)3.6 Min
Touch Panel4-Wire
VrefExt Int/Ext
  • Evaluation Modules & Boards: TSC2007EVM
    TSC2007EVM Evaluation Module
  • Evaluation Modules & Boards: TSC2007EVM-PDK
    TSC2007EVM Evaluation Module-PDK
  • TSC2007 Linux Driver
    PDF, 120 Кб, Файл опубликован: 31 мар 2009
    This application report describes the LinuxВ® operating system driver for the TSC2007 to help customers implement designs using the TSC2007 touch-screen controller. It also discusses the driver and associated code. The Linux driver code can be integrated into a customer's software system under different host processors. This driver has been tested and used on the Atmel AT91SAM9261EK platform.
  • TSC2007 WinCEВ® 5.0 Driver
    TSP, Файл опубликован: 31 мар 2009
    The TSC2007 Microsoft WindowsВ® CE (WinCE) 5.0 touch driver was developed with an IВІCв„ў control interface; the code has been tested on a Samsung SC32442 application processor. This application report discusses the TSC2007 driver, including the hardware connection between the TSC2007 and the platform, the WinCE 5.0 driver code structure, and the installations.
  • TSC2007 WinCE 6.0 Touch Drivers
    TSP, Файл опубликован: 29 апр 2009
    The TSC2007 Microsoft WindowsВ® CE (WinCE) 6.0 touch driver was developed with an IВІCв„ў control interface; the code has been tested on a Samsung SC32442 application processor. This application report discusses the TSC2007 driver, including the hardware connection between the TSC2007 and the platform, the WinCE 6.0 driver code structure, and the installations.
  • Migrating from TSC2003 to TSC2007
    PDF, 169 Кб, Файл опубликован: 17 июл 2007
    This application report describes the issues of interest related to migrating from the Texas Instruments (TI) TSC2003 to the TSC2007 touch screen controller. The objective is to highlight differences between the two devices and to provide guidelines for hardware and software changes required for the migration.
  • Important Considerations to Assure a Safe POR
    PDF, 115 Кб, Файл опубликован: 10 мар 2009
    This application report explains specific and important considerations related to the automatic power-on reset feature of the TSC2007 touch-screen controller. It also discusses several possible issues that may arise as a result of improperly powering the device on or off, and provides application solutions to ensure proper TSC2007 operation under various power-supply conditions.
  • Q2 2008 Issue Analog Applications Journal
    PDF, 1.3 Мб, Файл опубликован: 16 май 2008
    This document holds articles for specific application examples and technologies. It also includes a selection guide for antennas in low-power RF applications.
  • Using a touch-screen controller’s auxiliary inputs
    PDF, 149 Кб, Файл опубликован: 12 окт 2007
  • Operation Schemes of Touch Screen Controllers
    PDF, 846 Кб, Файл опубликован: 21 май 2007
  • PCB Layout Guideline for TI Resistive TSC Devices
    PDF, 144 Кб, Файл опубликован: 4 окт 2012
  • Reducing Analog Input Noise in Touch Screen Systems (Rev. A)
    PDF, 535 Кб, Версия: A, Файл опубликован: 15 сен 2007
    This application report discusses some common methods for reducing noise in the analog input circuitry of a resistive touch screen controller. In terms of hardware design, PCB layout and grounding are critical; the additional noise-decoupling capacitor built into a touch screen controller input pin may also help. On the software side, several simple, widely-applied filtering algorithms are present
  • Calibration in touch-screen systems
    PDF, 169 Кб, Файл опубликован: 10 авг 2007
  • Q4 2007 Issue Analog Applications Journal (Rev. A)
    PDF, 316 Кб, Версия: A, Файл опубликован: 14 ноя 2007
  • Apply TI TSC for Various and Multiple Functions
    PDF, 316 Кб, Файл опубликован: 11 дек 2006
    This application report presents several examples showing how a touch screen controller (TSC) from Texas Instruments provides a variety of functions such as graphs, scroll bars, pressure buttons, and analog dials. A simple resistive TSC can be used to achieve all of these functions as long as they are not activated simultaneously. This application report demonstrates a few simple examples how th
  • Semiconductors > Data Converters > Integrated/Special Function Data Converters > Touch Screen Controllers
На английском языке: Datasheet Texas Instruments TSC2007IPW
