Datasheet Texas Instruments TSC2008TRGVRQ1 — Даташит
СерияTSC2008-Q1
МодельTSC2008TRGVRQ1
Каталог для автомобилей Контроллер сенсорного экрана Nano-Power с SPI 16-VQFN -40 to 105
1.2V to 3.6V, 12-Bit, Nanopower, 4-Wire Micro TOUCH SCREEN CONTROLLER with SPIв„ў datasheet
PDF, 856 Кб, Файл опубликован: 28 июн 2011
Pin1616
Package TypeRGVRGV
Industry STD TermVQFNVQFN
JEDEC CodeS-PQFP-NS-PQFP-N
Package QTY20002000
CarrierLARGE T&RLARGE T&R
МаркировкаTSC2008T
Width (мм)44
Length (мм)44
Thickness (мм).9.9
Pitch (мм).65.65
Max Height (мм)11
Control InterfaceSPI
Тип входаSingle-Ended
Package GroupVQFN
Package Size: mm2:W x L16VQFN: 16 mm2: 4 x 4(VQFN) PKG
RatingAutomotive
SAR ADC Resolution12 Bits
SAR Sample Rate(Max)200 kSPS
Supply Voltage (Analog)1.2 Max
Supply Voltage (I/O VDD)3.6 Min
Touch Panel4-Wire
VrefExt Int/Ext
  • TSC2008 LinuxВ® Driver
    TSP, Файл опубликован: 31 мар 2009
    This application report describes the TSC2008 touch driver for the LinuxВ® operating system to help customers to implement designs using the TSC2008 touch-screen controller. It also discusses the driver and associated code. The Linux driver code can be integrated into a customer's software system under different host processors. The driver has been tested and used on the Atmel AT91SAM9261EK pla
  • Operation Schemes of Touch Screen Controllers
    PDF, 846 Кб, Файл опубликован: 21 май 2007
  • PCB Layout Guideline for TI Resistive TSC Devices
    PDF, 144 Кб, Файл опубликован: 4 окт 2012
  • Calibration in touch-screen systems
    PDF, 169 Кб, Файл опубликован: 10 авг 2007
  • Reducing Analog Input Noise in Touch Screen Systems (Rev. A)
    PDF, 535 Кб, Версия: A, Файл опубликован: 15 сен 2007
    This application report discusses some common methods for reducing noise in the analog input circuitry of a resistive touch screen controller. In terms of hardware design, PCB layout and grounding are critical; the additional noise-decoupling capacitor built into a touch screen controller input pin may also help. On the software side, several simple, widely-applied filtering algorithms are present
Серия: TSC2008-Q1 (1)
  • TSC2008TRGVRQ1
  • Semiconductors > Data Converters > Integrated/Special Function Data Converters > Touch Screen Controllers
На английском языке: Datasheet Texas Instruments TSC2008TRGVRQ1
