Datasheet Texas Instruments TSC2013QRSARQ1 — Даташит
Серия | TSC2013-Q1 |
Модель | TSC2013QRSARQ1 |
1,2 В - 3,6 В, 12-битный, Nanopower, 4-проводной контроллер сенсорного экрана 16-QFN -40 - 125
TSC2013-Q1 12-Bit, Nanopower, 4-Wire Dual-Touch Screen Controller With I2C Interface datasheet
PDF, 1.6 Мб, Версия: A, Файл опубликован: 24 июл 2014
Pin | 16 | 16 |
Package Type | RSA | RSA |
Industry STD Term | VQFN | VQFN |
JEDEC Code | S-PQFP-N | S-PQFP-N |
Package QTY | 2500 | 2500 |
Carrier | LARGE T&R | LARGE T&R |
Маркировка | TSC | 2013Q |
Width (мм) | 4 | 4 |
Length (мм) | 4 | 4 |
Thickness (мм) | .9 | .9 |
Pitch (мм) | .65 | .65 |
Max Height (мм) | 1 | 1 |
Control Interface | I2C |
Тип входа | Differential |
Package Group | QFN |
Package Size: mm2:W x L | 16QFN: 16 mm2: 4 x 4(QFN) PKG |
Rating | Automotive |
SAR ADC Resolution | 12 Bits |
Supply Voltage (Analog) | 1.6 Max |
Supply Voltage (I/O VDD) | -0.4 Max |
Touch Panel | 4-Wire |
Vref | Ext Int/Ext |
- Evaluation Modules & Boards: TSC2013EVM
TSC2013-Q1 Evaluation Module for Automotive Resistive Touch Screen Controller
- Operation Schemes of Touch Screen ControllersPDF, 846 Кб, Файл опубликован: 21 май 2007
- PCB Layout Guideline for TI Resistive TSC DevicesPDF, 144 Кб, Файл опубликован: 4 окт 2012
- Calibration in touch-screen systemsPDF, 169 Кб, Файл опубликован: 10 авг 2007
- Reducing Analog Input Noise in Touch Screen Systems (Rev. A)PDF, 535 Кб, Версия: A, Файл опубликован: 15 сен 2007
This application report discusses some common methods for reducing noise in the analog input circuitry of a resistive touch screen controller. In terms of hardware design, PCB layout and grounding are critical; the additional noise-decoupling capacitor built into a touch screen controller input pin may also help. On the software side, several simple, widely-applied filtering algorithms are present
Серия: TSC2013-Q1 (2)
- TSC2013QPWRQ1 TSC2013QRSARQ1
- Semiconductors > Data Converters > Integrated/Special Function Data Converters > Touch Screen Controllers
