Помощь в переводе проектов на ПЛИС азиатских брендов
Datasheet Texas Instruments TSC2100IDA — Даташит
СерияTSC2100
МодельTSC2100IDA
4-проводной контроллер сенсорного экрана со стерео ЦАП / моно АЦП с усилителем HP/Speaker 32-TSSOP -40 to 85
TSC2100: Programmable Touch Screen Controller datasheet
PDF, 1.4 Мб, Файл опубликован: 5 ноя 2003
АЦП азиатских производителей
Pin32
Package TypeDA
Industry STD TermTSSOP
Package QTY46
МаркировкаTSC2100I
Width (мм)6.2
Length (мм)11
Thickness (мм)1.15
Max Height (мм)1.2
  • Evaluation Modules & Boards: TSC2100EVM
    TSC2100 Evaluation Module (EVM)
  • TSC2100 WinCE5.0 Drivers
    PDF, 217 Кб, Файл опубликован: 20 фев 2006
    This application report discusses the TSC2100 touch screen and audio WinCE 5.0 drivers, running on an Intelв„ў PXA27x processor. The associated driver code was tested with a Texas Instruments TSC2100 evaluation module (EVM) on an Intel MainStone II platform.
  • TSC2101 Touch Screen, Battery and Audio WinCE Drivers
    PDF, 252 Кб, Файл опубликован: 12 апр 2004
    This application report describes the TSC2101 touch screen, battery, and audio drivers for the WinCE operating system to help customers to implement designs using the TSC2101 audio CODEC with integrated headphone/speaker amplifier, and touch-screen controller. The drivers and associated code are discussed. The WinCE driver code can be integrated into the customer?s software system under different
  • TSC2100 WinCE Generic Drivers
    PDF, 206 Кб, Файл опубликован: 8 мар 2004
    This application report develops and presents the TSC2100 touchscreen and audio WinCE drivers. These generic drivers can be used on or adapted to different processors or processor platforms. The associated driver code was tested with the Intel(TM) Lubbock and MainStone platforms.
  • Using the PGA Function in TSC210x/AIC26/AIC28/DAC26 Devices
    PDF, 453 Кб, Файл опубликован: 3 июн 2005
    TI's touch screen and audio codec/DAC devices, such as the TSC2100, TSC2101, TSC2102, TLV320AIC26, TLV320AIC28, and the TLC320DAC26, have one or more audio-band programmable gain amplifiers (PGA) in their input circuitry. This application report describes how to implement this PGA function using the TLV320DAC26 as an example.
  • Programming Audio Power Up/Down on TSC210x & TLV320AIC26/28 (Rev. A)
    PDF, 61 Кб, Версия: A, Файл опубликован: 5 май 2005
    This application report presents some general and practical programming sequences for the audio power up/down of Texas Instruments TSC2100/TSC2102/TLV320AIC26 and TSC2101/TLV320AIC28 devices, so as to avoid a possible malfunction or errors during and after power up or down.
  • The Built-In AGC Function in TSC2100/2101 & TLV320AIC26/28/32/33 Devices
    PDF, 188 Кб, Файл опубликован: 13 сен 2005
    Applying the built-in AGC function requires initializing or setting up a group of corresponding control registers inside the TSC2100/01 and TLV320AIC26/28/32/33 devices. This application report describes how to set up the AGC properly and provides examples.
  • Interface TSC Through McBSP
    PDF, 221 Кб, Файл опубликован: 28 окт 2004
    This application report develops and presents the methodology to interface TI's touch screen controller products and multichannel buffered serial ports (McBSP) through SPI and I2S buses. The interface software code is designed and tested using the TMS320VC5416 DSK and the TSC2100 EVM.
  • How to Set the TSC/AIC EVM to Record & Playback Audio or Other Sound Through PC
    PDF, 480 Кб, Файл опубликован: 14 дек 2004
    Record and playback audio, sound, or voice on a TI touch screen controller (TSC) or audio codec (AIC) EVM system by means of the associated software running on a PC system. The PC and EVM are connected using a USB cable. This application report gives an example to demonstrate how to do this through a Windows XP? PC system. The block diagram and connection are shown in Figure 1.
Серия: TSC2100 (4)
  • Semiconductors > Audio > Touch Screen Controller with Audio
На английском языке: Datasheet Texas Instruments TSC2100IDA
