Datasheet Texas Instruments TUSB3200ACPAHR — Даташит
СерияTUSB3200A
МодельTUSB3200ACPAHR
USB-контроллер потоковой передачи 52-TQFP от 0 до 70
TUSB3200A USB Streaming Controller (STC) datasheet
PDF, 2.0 Мб, Версия: B, Файл опубликован: 2 фев 2011
Микросхема Микроконтроллер, Full Speed USB Streaming Controller 3.3V T/R 52Pin TQFP
TUSB3200ACPAHR
647 ₽
Hi-Tech Circuit Group
TUSB3200ACPAHR
727GS
TUSB3200ACPAHR
TUSB3200ACPAHR
Pin52
Package TypePAH
Industry STD TermTQFP
JEDEC CodeS-PQFP-G
МаркировкаTUSB3200AC
Width (мм)10
Length (мм)10
Thickness (мм)1
Max Height (мм)1.2
  • I2C and the TAS3001C
    PDF, 81 Кб, Файл опубликован: 21 фев 2001
    The TAS3001C stereo audio digital equalizer provides a serial control interface using the I2C protocol. Since the TAS3001C is more complex than the typical serial EEPROM often found on an I2C bus, designers must consider additional aspects of the I2C specification. Methods of interfacing to the TAS3001C, applicable to a wide variety of I2C masters, are discussed.
  • TLC320AD77C Clock and Timing Issues
    PDF, 97 Кб, Файл опубликован: 27 июн 2001
    The Texas Instruments TLC320AD77C stereo audio codec requires a 3-ns separation in edges between MCLK and SCLK and an LRCLK phase stability of +/-10 MCLKs over the duration that power is applied. This paper examines the source of these requirements and the impact they have on a design when using the codec with the Texas Instruments TMS320C54x DSP and the Texas Instruments TUSB3200 USB Control
Серия: TUSB3200A (3)
  • Semiconductors > Staging > Unknown > USB Streaming Controller
На английском языке: Datasheet Texas Instruments TUSB3200ACPAHR
