Datasheet Texas Instruments TUSB546A-DCIRNQT — Даташит
СерияTUSB546A-DCI
МодельTUSB546A-DCIRNQT
USB Type-C™ DP ALT Mode Линейный редрайвер Кросс-переключатель 40-WQFN 0 to 70
TUSB546A-DCI USB Type-Cв„ў DP ALT Mode Linear Redriver Crosspoint Switch datasheet
PDF, 1.2 Мб, Файл опубликован: 26 июн 2017
36 предложений от 15 поставщиков
5GBPS TYPEC DP ALT MODE REDRIVER. Buffer, ReDriver 2 Channel 8.1Gbps 40-WQFN (4x6). Interface - Signal Buffers, Repeaters, Splitters
TUSB546A-DCIRNQT
от 125 ₽
TUSB546A-DCIRNQT
483 ₽
TUSB546A-DCIRNQT
539 ₽
TUSB546A-DCIRNQT
Pin40
Package TypeRNQ
Industry STD TermWQFN
JEDEC CodeR-PQFP-N
Package QTY250
CarrierSMALL T&R
МаркировкаTUSB46
Width (мм)4
Length (мм)6
Thickness (мм).75
Pitch (мм).4
Max Height (мм).8
Alternate ModeYes
ConfigurationAlternate mode / Source
Data RoleDFP
Dead Battery SupportNo
External Power Path ControlN/A
FunctionActive Signal Switch
Internal Power PathN/A
Package GroupWQFN
Policy ManagerN/A
Power RoleN/A
Realtime VBUS monitoringNo
USB Speed5000 Mbps
  • Enabling HDMI over Type-C using TUSB564A-DCI
    PDF, 141 Кб, Файл опубликован: 12 сен 2017
    The TUSB546A-DCI is a linear redriver that supports both USB3.1 Gen1 and DisplayPort 1.4 over a USB Type-C interface.Even though the TUSB546A-DCI was released for the DisplayPort Alternate mode, the TUSB546A-DCI can also be used as a redriver in a USB-C HDMI Alternate mode source application. This document is intended to describe how to use the TUSB546A-DCI in a HDMI Type-C source application. T
  • TUSB546A-DCI, TUSB1046A-DCI: Enabling DCI
    PDF, 110 Кб, Файл опубликован: 29 авг 2017
    The TUSB546A-DCI and TUSB1046A-DCI is a Type-C linear redriver mux intended for Type-C source applications. The TUSB546A-DCI multiplexes between four DP1.4 lanes and USB3.1 Gen1 (5Gbps) to a single Type-C receptacle. The TUSB1046A-DCI multiplexes between four DP1.4 lanes and USB3.1 Gen2 (10Gbps) to a single Type-C receptacle. For the remainder of the document TUSBx46 notation will be used to descr
Серия: TUSB546A-DCI (2)
  • Semiconductors > Interface > USB > USB Type-C and Power Delivery
TUSB546ADCIRNQT, TUSB546A DCIRNQT
На английском языке: Datasheet Texas Instruments TUSB546A-DCIRNQT
