Datasheet Texas Instruments TYCOF2812PGFA — Даташит
СерияTMS320F2812
МодельTYCOF2812PGFA
32-битный контроллер цифровых сигналов с флэш-памятью 176-LQFP от -40 до 85
TMS320F2810, TMS320F2811, TMS320F2812, TMS320C2810, TMS320C2811,TMS320C2812 DSPs datasheet
PDF, 2.1 Мб, Версия: T, Файл опубликован: 31 май 2012
Pin176176
Package TypePGFPGF
Industry STD TermLQFPLQFP
JEDEC CodeS-PQFP-GS-PQFP-G
Package QTY4040
CarrierJEDEC TRAY (5+1)JEDEC TRAY (5+1)
Маркировка320F2812PGFATMS
Width (мм)2424
Length (мм)2424
Thickness (мм)1.41.4
Pitch (мм).5.5
Max Height (мм)1.61.6
ADC16 Ch
ADC Resolution12-bit
Additional FeaturesExternal Interface (XINTF),Single Zone Code Security,32-bit CPU Timers,Watchdog Timer,2-pin Oscillator,AEC-Q100 Automotive Qual
Analog to Digital ConverterADC12: 2-S/H, 12.5-MSPS ADC
CAN1
CAP6
CPUC28x
FPUNo
Flash256 KB
Тактовая частота150 МГц
GPIO56
Other Actuation FeaturesN/A
Other Connectivity FeaturesMcBSP,CAN
Other Sensing FeaturesN/A
PWM16 Ch
PWM Technology TypeEV
Package GroupLQFP
Package Size: mm2:W x L176LQFP: 576 mm2: 24 x 24(LQFP) PKG
Processing AcceleratorsN/A
QEP2
RAM36 KB
SPI1
Total Processing150 MIPS
UART2 SCI
  • Development Kits: TMDSEZD2812
    TMS320F2812 eZdsp Start Kit (DSK)
  • Development Kits: TMDSEZS2812
    TMS320F2812 eZdsp Starter Kit (DSK) - Socketed version
  • Evaluation Modules & Boards: TMDSEVP2812
    F2812 Development Bundle with PP+ Emulator
  • Evaluation Modules & Boards: TMDSEVU2812
    F2812 Development Bundle with USB Emulator
  • JTAG Emulators/ Analyzers: C2000-GANG
    C2000 Gang Programmer
  • JTAG Emulators/ Analyzers: TMDSEMU100V2U-20T
    XDS100v2 JTAG Debug Probe (20-pin cTI version)
  • JTAG Emulators/ Analyzers: TMDSEMU100V2U-14T
    XDS100v2 JTAG Debug Probe (14-pin TI version)
    XDS200 USB Debug Probe
  • Controlling the ADS8342 with TMS320 Series DSP's
    PDF, 109 Кб, Файл опубликован: 22 сен 2003
    The ADS8342 16-bit, bipolar input, parallel output analog-to-digital converter has a number of features that allow for an easy interface to many of the TMS320? DSP family of digital signal processors from Texas Instruments. This application note focuses on configuring, sampling, and converting analog data presented to the ADS8342 ADC, with software examples using the TMS320C6711 and C5416 DSPs. Th
  • Interfacing the ADS8361 to the TMS320F2812 DSP
    PDF, 111 Кб, Файл опубликован: 10 фев 2003
    This application note presents several methods for interfacing the ADS8361 16-bit SAR analog-to-digital converter to the TMS320F2812DSP. The software developed for this application note uses both the McBSP and SPI port to highlight the flexible digital interface of the ADS8361. In an effort to reduce development time, the source code for this application note can be found on the Texas Instrument
  • TMS320F281x Flash Programming API Revision Change
    PDF, 63 Кб, Файл опубликован: 17 авг 2005
    TMS320F281x Flash API version 1.00 has been revised to version 2.10. This document provides a list of questions and answers concerning the effect of the mandatory updates on existing applications.
  • TMS320F2810, TMS320F2811, TMS320F2812 ADC Calibration (Rev. A)
    PDF, 222 Кб, Версия: A, Файл опубликован: 30 ноя 2004
    This application note describes a method for improving the absolute accuracy of the 12-bit analog-to-digital converter (ADC) found on the F2810/F2811/F2812 devices. Due to inherent gain and offset errors, the absolute accuracy of the ADC is impacted. The methods described in this application note can improve the absolute accuracy of the ADC to achieve levels better than 0.5%. This application note
  • TMS320F281x Boot ROM Serial Flash Programming
    PDF, 5.5 Мб, Файл опубликован: 11 окт 2007
    This application report describes the implementation of TI's Flash application program interface (API), the software interface to TI's Flash algorithms. Understanding the fundamentals of the Flash API documentation prior to using this application report is important. This document does not replace the Flash API documentation; instead, it guides you among several sets of TI documentation with the F
  • Signal Conditioning an LVDT Using a TMS320F2812 DSP
    PDF, 428 Кб, Файл опубликован: 15 авг 2003
    A linear variable differential transformer (LVDT) is a type of electro-mechanical transducer capable of measuring linear displacement with a high degree of accuracy. The transducer requires external electronic circuitry to produce a stable reference oscillator, and condition the return signal in order to determine displacement. Traditional LVDT circuits are based on analog design techniques, and s
  • Interfacing the ADS8364 to the TMS320F2812 DSP
    PDF, 78 Кб, Файл опубликован: 11 дек 2002
    The ADS8364 16-bit parallel output analog-to-digital converter has a number of features that allow for an easy interface to the TMS320F2812в„ў digital signal processor. This application note focuses on configuring, sampling, and converting analog data presented to the ADS8364 ADC. Portions of ports A, E, and F are used for general-purpose control, while the parallel data bus accepts data fro
  • Converting Analog Controllers to Smart Controllers with the TMS320C2000 DSPs
    PDF, 319 Кб, Файл опубликован: 7 июн 2004
    Modern applications demand faster, cheaper, and better motor control systems, and the performance demanded from embedded motor controllers is ever increasing. Programmable controllers offer the unique opportunity to improve performance, reduce cost, and enable designers to improve the efficiency of motor control systems. Such performance objectives typically need advanced algorithms that are compu
  • DSP Control of Electro-Hydraulic Servo Actuators
    PDF, 574 Кб, Файл опубликован: 28 янв 2005
    Hydraulic actuators are characterized by their ability to impart large forces at high speeds and are used in many industrial motion systems. In applications where good dynamic performance is important it is common to contain the actuator in a servo loop comprising a feedback transducer and electronic controller. The majority of electronic servo-controllers used in these systems are analogue based
  • A Software Modularity Strategy for Digital Control Systems
    PDF, 499 Кб, Файл опубликован: 6 сен 2000
  • Code Composer Studioв„ў IDE v2.2 Profiler
    PDF, 57 Кб, Файл опубликован: 7 апр 2003
    This application note will outline and discuss the Code Composer Studio Profiler and how to use it in accurately profiling an application. We will explain the various types of profiling and will detail the differences between simulator profiling and emulator profiling.Requirements:Windows 98 (SP1/SE), Windows NT SP6, Windows 2000 (SP1/SP2), Windows XP Home and ProCode Co
  • DSP Solutions for the Switched Reluctance Motor
    PDF, 112 Кб, Файл опубликован: 1 янв 1997
    This document deals with solutions to control a switched reluctance motor using the TMS320C24x. This new DSP family enables cost-effective design of intelligent controllers for switched reluctance motors. Two speed control algorithms are presented, they allow the Switched Reluctance motor drive to reach high efficiency, smooth operation, very good dynamic behavior, very high speed and low acoustic
  • A Variable-Speed Sensorless Drive System for Switched Reluctance Motors
    PDF, 246 Кб, Файл опубликован: 30 окт 1999
    With the advent of high-speed digital signal processors (DSPs) specialized for motion control applications, it has become possible to control motors without mechanical (speed or position) sensors. This is achieved by algorithms that estimate the desired quantities in real time, based on the electrical signals in the motor windings. Benefits include cost savings and improved reliability due to redu
  • Microstepping Bipolar Drive of Two-Phase Hybrid Stepping Motor on F2808 DSP
    PDF, 1.7 Мб, Файл опубликован: 2 май 2008
    This application report describes the implementation of a micro-stepping algorithm for a two-phase stepper motor using the TMS320F2808 digital signal controller (DSC). The "C" code can easily be utilized with other members of the C2000в„ў DSC platform of devices.
  • Spread-Frequency Shift Keying Power Line Modem Software Architecture
    PDF, 703 Кб, Файл опубликован: 16 июн 2006
    This application report describes the software architecture and design of the Spread-Frequency Shift Keying Power Line Modem demonstration platform. Each demonstration unit consists of an eZdsp DSP developer's board plus a daughter card. The daughter card contains electronics that shape and amplify the power line communications (PLC) transmit signal, filter the PLC receive signal, handle RS-232 se
  • TMS320C2000в„ў DSP Controllers: A Perfect Fit for Solar Power Inverters
    PDF, 437 Кб, Файл опубликован: 5 май 2006
    A worldwide concern for future access to affordable, sustainable energy is driving the development of more efficient solar power generation. In any photovoltaic (PV) based system, the inverter is a critical component responsible for the control of electricity flow between the module, battery, loads, and power grid. Inverters, which convert direct to alternating current, can be designed to be used
  • 3.3 V DSP for Digital Motor Control
    PDF, 138 Кб, Файл опубликован: 29 апр 1999
    New generations of motor control digital signal processors (DSPs) lower their supply voltages from 5V to 3.3V to offer higher performance at lower cost. Replacing traditional 5V digital control circuitry by 3.3V designs introduce no additional system cost and no significant complication in interfacing with TTL and CMOS compatible components, as well as with mixed voltage ICs such as power transist
  • Optimizing Digital Motor Control Libraries
    PDF, 365 Кб, Файл опубликован: 15 мар 2007
    The DMC library contains a collection of component modules and system implementations, which are intended for evaluation, accelerated design, and development of motor control firmware.The software is intended to meet these goals, and no optimization is performed.As system designers implement systems, they must optimize their systems for performance in terms of memory consumption and CPU cyc
  • Migrating Code Composer v4.12 Projects to Code Composer Studio v2.0
    PDF, 117 Кб, Файл опубликован: 11 июл 2002
    This application report describes the process of migrating an existing Code Composer v4.12 project to a Code Composer Studio? Integrated Development Environment (IDE) v2 project.
  • Hardware Design Guidelines for TMS320F28xx and TMS320F28xxx DSCs (Rev. C)
    PDF, 311 Кб, Версия: C, Файл опубликован: 10 июн 2015
    TMS320F28xx and F28xxx digital signal controllers (DSCs) include multiple complex peripherals running at fairly high-clock frequencies. They are commonly connected to low level analog signals using an onboard analog-to-digital converter (ADC). This application report is organized as a guide for system level hardware design, parts selection, and schematics design to board layout and helps in avoidi
  • TMS320x281x to TMS320x280x/2801x/2804x Migration Overview (Rev. A)
    PDF, 124 Кб, Версия: A, Файл опубликован: 5 окт 2006
    This application report describes differences between the Texas Instruments TMS320x281x and TMS320x280x/2801x/2804x DSPs to assist in application migration from the 281x to the 280x. While the main focus of this document is migration from 281x to 280x/2801x/2804x, users considering migrating in the reverse direction (280x to 281x) will also find this document useful. Functions that are identical
  • Calculating Useful Lifetimes of Embedded Processors
    PDF, 521 Кб, Файл опубликован: 11 ноя 2014
    This application report provides a methodology for calculating the useful lifetime of TI embedded processors (EP) under power when used in electronic systems. It is aimed at general engineers who wish to determine if the reliability of the TI EP meets the end system reliability requirement.
  • Power Line Communication for Lighting Apps using BPSK w/ a Single DSP Controller
    PDF, 1.7 Мб, Файл опубликован: 7 мар 2006
    DSP controllers provide the on-chip peripherals and computational power needed to implement various power electronics applications. A single-chip DSP controller allows designers to implement multiple functions such as power line communication, power-factor correction, and inverter control, all needed for an overall dimmable lighting ballast application. This application report presents a complete
  • Recommended Power Solutions for the TMS320x2810/1/2 DSPs
    PDF, 28 Кб, Файл опубликован: 31 янв 2005
    This application report provides a table to assist users in selecting the best power solution for their specific TMS320281x application.
  • Custom Bootloader Options via One-Time Programmable (OTP) Memory
    PDF, 62 Кб, Файл опубликован: 18 сен 2007
    The Boot to One-Time-Programmable (OTP) memory mode in the TMS320x280x devices provides the necessary hooks to support custom bootloaders. This is very useful in a situation where a bootloader option, required by a specific customer application, is not already supported as one of the built-in options in the Boot read-only memory (ROM). This application report includes information and examples on h
  • Interfacing SD/MMC Cards With TMS320F28xxx DSCs
    PDF, 1.3 Мб, Файл опубликован: 26 июл 2007
    This application report and associated code implements the interfacing of Secure Digital (SD) or Multi-Media Card (MMC) types of Flash memory cards with the TMS320F28xxx digital signal controllers (DSCs). These cards can use serial peripheral interface (SPI) or parallel (SD) interface to connect to the host. This application report demonstrates the SPI mode and includes the schematics showing th
  • An Easy Way of Creating a C-callable Assembly Function for the TMS320C28x DSP
    PDF, 185 Кб, Файл опубликован: 30 окт 2001
    C-callable assembly routines require an understanding of parameter-passing conventions and environments expected by the C compiler. This application report provides instructions and suggestions to configure the C compiler to assist with these issues.
  • An Overview of Designing Analog Interface With TM320F28xx/28xxx DSCs (Rev. A)
    PDF, 655 Кб, Версия: A, Файл опубликован: 14 май 2008
    This application report provides guidelines that take you through everything from configuring the ADC and related registers correctly, responding to interrupts, and board design recommendations; this may be particularly useful for first-time users of the TMS320C2000в„ў digital signal processor (DSP) platform devices and for firmware engineers with less exposure to the analog world. Various s
  • Copying Compiler Sections from Flash to RAM on the TMS320F28xxx DSCs (Rev. A)
    PDF, 307 Кб, Версия: A, Файл опубликован: 18 авг 2017
    This application report and associated code files provide functionality for copying initialized compiler sections from the internal Flash memory to the internal random access memory (RAM) of the TMS320F28xxx digital signal controllers (DSCs) at run time for optimizing execution speed. The solution provided implements this functionality directly after booting before entering the c_int00 C entry rou
  • Online Stack Overflow Detection on the TMS320C28x DSP
    PDF, 407 Кб, Файл опубликован: 2 май 2003
    A stack overflow in an embedded DSP application generally produces a catastrophic software crash due to data corruption, lost return addresses, or both. Traditional off-line approaches to sizing a stack during development, such as filling with a know value, or estimating based on code content, are not 100% reliable. Therefore, programmers often feel compelled to reserve larger stack sizes than are
  • Programming Examples for the TMS320x28xx eCAN (Rev. B)
    PDF, 73 Кб, Версия: B, Файл опубликован: 12 сен 2017
    The TMS320x28xx series of Microcontrollers/Digital Signal Controllers feature an on-chip enhanced Controller Area Network (eCAN) module. This module is a full-CAN controller, compliant with CAN specification 2.0B. This application report contains several programming examples, supplemental to those in C2000Ware/controlSUITE, to illustrate how the eCAN module is set up for different modes of operati
  • Running an Application from Internal Flash Memory on the TMS320F28xxx DSP (Rev. L)
    PDF, 641 Кб, Версия: L, Файл опубликован: 28 фев 2013
    Several special requirements exist for running an application from on-chip Flash memory on the TMS320F28xxx. These requirements generally do not manifest themselves during code development in RAM since the Code Composer Studioв„ў (CCS) debugger can mask problems associated with initialized sections and their linkage in memory. This application report covers the application software modificatio
  • Flash Programming Solutions for the TMS320F28xxx DSCs
    PDF, 423 Кб, Файл опубликован: 19 авг 2008
    Flash programming is a process that occurs during all stages of a TMS320F28xxx digital signal controller (DSC) development cycle: firmware debug, prototyping, production, and field reprogramming. Several solutions are available to accommodate programming for all of these development stages. This application report presents solutions that are available and at what stage in the development cycle the
  • Programming TMS320x28xx and 28xxx Peripherals in C/C++ (Rev. D)
    PDF, 530 Кб, Версия: D, Файл опубликован: 27 фев 2013
    This application report explores a hardware abstraction layer implementation to make C/C++ coding easier on C28x devices. This method is compared to traditional #define macros and topics of code efficiency and special case registers are also addressed.
  • EEPROM Emulation With the TMS320F28xxx DSCs
    PDF, 407 Кб, Файл опубликован: 21 сен 2009
    Many applications require storing small quantities of system related data (e.g., calibration values, device configuration) in a non-volatile memory, so that it can be used or modified and reused even after power cycling the system. EEPROMs are primarily used for this purpose. EEPROMs have the ability to erase and write individual bytes of memory many times over and the programmed locations retain
  • Calculator for CAN Bit Timing Parameters
    PDF, 37 Кб, Файл опубликован: 22 мар 2016
    Controller Area Network (CAN) nodes use user-specified timing parameters to sample the asynchronous bitstream and recover the clock. These parameters are typically based on the frequency of the available reference oscillator. There may be several options available for a given frequency, and some of them will allow a looser oscillator tolerance than others. This application report details the creat
  • Programming External Nonvolatile Memory Using SDFlash for TMS320C28x Devices
    PDF, 2.0 Мб, Файл опубликован: 16 ноя 2009
    The C28xxx generation of microcontrollers can connect to external nonvolatile memory through a variety of interfaces including parallel, serial peripheral interface (SPI), and inter-integrated circuit (I2C). This application report discusses how to write drivers for your external nonvolatile memory to allow for in-place programming using SDFlash, an application provided by Spectrum Digital, Inc. A
  • Common Object File Format (COFF)
    PDF, 125 Кб, Файл опубликован: 15 апр 2009
  • TPS75005 Quick-Start Guide with C2000 Controllers
    PDF, 129 Кб, Файл опубликован: 17 янв 2012
    The TPS75005 is a complete power management solution for C2000 controllers from Texas Instruments. This document illustrates how to attach the TPS75005 to a C2000 controller.
  • Semiconductors > Microcontrollers (MCU) > Performance MCUs > Real-time Control > Fixed-point F280x/1x
На английском языке: Datasheet Texas Instruments TYCOF2812PGFA
