Datasheet Texas Instruments UC1637J — Даташит
СерияUC1637
МодельUC1637J
Контроллер переключаемого режима для привода двигателя постоянного тока 18-CDIP от -55 до 125
Switched Mode Controller for DC Motor Drive datasheet
PDF, 902 Кб, Файл опубликован: 5 сен 1999
15 предложений от 15 поставщиков
Драйвер электродвигателя, PWM Motor Controller 18Pin CDIP Tube
UC1637J883B
439 ₽
UC1637J
UC1637J/883
UC1637J/883
Pin18
Package TypeJ
Industry STD TermCDIP
JEDEC CodeR-GDIP-T
Package QTY1
МаркировкаUC1637J
Width (мм)6.92
Length (мм)23.1
Thickness (мм)4.57
Pitch (мм)2.54
Max Height (мм)5.08
Package GroupCDIP
RatingMilitary
Special FeaturesCurrent-Limited,DC Motor Control,Switching Control
RoHSSee ti.com
  • DN-53A Design Considerations for Synchronizing Multiple UC3637 PWMs
    PDF, 168 Кб, Файл опубликован: 5 сен 1999
    The UC3637 is an extremely versatile PWM used in many motor-control and power-driver applications, so the need for synchronization often arises. For proper synchronization, a few simple design rules must be followed. These rules apply primarily to resetting the part's current-limit latches. This design note discusses several types of circuits for synchronizing multiple PWMs and presents two simple
  • U-102 UC1637/2637/3637 Switched Mode Controller for DC Motor Drive
    PDF, 350 Кб, Файл опубликован: 5 сен 1999
    The UC1637 switched-mode controller for DC motors is one of several integrated circuits offered by Unitrode for motor controls. This application note presents the general principles of its operation and the circuit details that optimize its use. It includes a design that will involves not only the UC1637, but also a power H-bridge using MOSFET transistors, and a modern DC motor tachometer. Using t
  • U-112 A High Precision PWM Transconductance Amplifier for Microstepping
    PDF, 211 Кб, Файл опубликован: 5 сен 1999
    The UC1637 is a pulse-width modulator circuit for a variety of PWM motor drive and amplifier applications requiring either unidirectional or bidirectional drive circuits. When used to replace conventional drivers, this circuit can increase efficiency and reduce component costs for many applications. However, stepping motors are incremental motion machines, and so are sometimes erratic, for example
  • U-120 A Simplified Approach to DC Motor Modeling for Dynamic Stability Analysis
    PDF, 106 Кб, Файл опубликован: 5 сен 1999
    When we say that an electric motor is a device that transforms electric power into mechanical power we say two things. First that the motor is ?and behaves as ?a transformer. Second that it stands at the dividing line between electrical and mechanical phenomena. In the case of permanent magnet motors this power transformation works in both directions so that the electrical impedance depends on
  • Semiconductors > Space & High Reliability > Power Management Products > Power Management Special Function Products
На английском языке: Datasheet Texas Instruments UC1637J
