Datasheet Texas Instruments UC1903J — Даташит
| Серия | UC1903 |
| Модель | UC1903J |
Четырехканальный блок питания и линейный монитор 18-CDIP от -55 до 125
Quad Supply and Line Monitor datasheet
PDF, 796 Кб, Версия: A, Файл опубликован: 26 авг 2008
Купить UC1903J на РадиоЛоцман.Цены — от 299 до 15 400 ₽18 предложений от 18 поставщиков Чип контроля напряжения, IC,VOLT DETECTOR,ADJUSTABLE,BIPOLAR,DIP,18Pin,CERAMIC | |||
| UC1903J Texas Instruments | 299 ₽ | ||
| UC1903J883B Texas Instruments | 8 557 ₽ | ||
| UC1903J Texas Instruments | по запросу | ||
| UC1903J/883B Texas Instruments | по запросу | ||
| Pin | 18 |
| Package Type | J |
| Industry STD Term | CDIP |
| JEDEC Code | R-GDIP-T |
| Package QTY | 1 |
| Carrier | TUBE |
| Маркировка | UC1903J |
| Width (мм) | 6.92 |
| Length (мм) | 23.1 |
| Thickness (мм) | 4.57 |
| Pitch (мм) | 2.54 |
| Max Height (мм) | 5.08 |
| Mechanical Data | Скачать |
| # of Supplies Monitored | 4 |
| Iq(Typ) | 7000 uA |
| Monitored Voltage 1 (typ)(Nom) | Adjustable В |
| Рабочий диапазон температур | от -55 до 125 C |
| Output Driver Type / Reset Output | Active-low,Open-drain |
| Package Group | CDIP |
| Package Size: mm2:W x L | See datasheet (CDIP) PKG |
| Rating | Military |
| Reset Threshold Accuracy | 3 % |
| Special Features | Negative Voltage Monitoring,Over Voltage Sense |
| Threshold Voltage 1(Typ) | 1.8 В |
| Threshold Voltage 2 (typ)(Typ) | Adjustable В |
| Time Delay | Programmable ms |
| VCC(Max) | 40 В |
| VCC(Min) | 8 В |
| Watchdog Timer WDI | None sec |
| RoHS | See ti.com |
- DN-33 Optocoupler Feedback Drive Techniques Using the UC3901 and UC3903PDF, 45 Кб, Файл опубликован: 5 сен 1999
A variety of low-cost supervisory ICs contain the required building blocks for the more demanding optocoupler feedback drive applications. Initially developed to address other specific power supply tasks several control ICs excel in the role as precision optocoupler control and drivers. This design note describes a basic optocoupler driver circuit and also a more advanced optocoupler drive circ - Optimizing Resistor Dividers at a Comparator (Rev. A)PDF, 120 Кб, Версия: A, Файл опубликован: 3 июн 2013
- Choosing an Appropriate Pull-up/Pull-down Resistor for Open Drain OutputsPDF, 130 Кб, Файл опубликован: 19 сен 2011
Серия: UC1903 (6)
- Semiconductors > Space & High Reliability > Power Management Products > Supervisor and Reset ICs
