Datasheet Texas Instruments UC2625DWTR — Даташит
Серия | UC2625 |
Модель | UC2625DWTR |
Brushless DC Motor Controller 28-SOIC -40 to 85
UCX625 Brushless DC Motor Controller datasheet
PDF, 869 Кб, Версия: C, Файл опубликован: 22 май 2013
Купить UC2625DWTR на РадиоЛоцман.Цены — от 484 до 4 310 ₽ 15 предложений от 12 поставщиков Motor Driver Power MOSFET, Power Darlington Parallel 28-SOIC | |||
UC2625DWTR Texas Instruments | 484 ₽ | ||
UC2625DWTR Texas Instruments | 657 ₽ | ||
UC2625DWTR Texas Instruments | от 4 310 ₽ | ||
UC2625DWTR Texas Instruments | по запросу |
Pin | 28 |
Package Type | DW |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 1000 |
Carrier | LARGE T&R |
Маркировка | UC2625DW |
Width (мм) | 7.5 |
Length (мм) | 17.9 |
Thickness (мм) | 2.35 |
Pitch (мм) | 1.27 |
Max Height (мм) | 2.65 |
Mechanical Data | Скачать |
Operating Supply Current | 14.5 мА |
Operating Supply(Max) | 18 В |
Operating Supply(Min) | 10 В |
Package Group | SOIC |
Package Size: mm2:W x L | 28SOIC: 184 mm2: 10.3 x 17.9(SOIC) PKG |
Peak Output Current | 0.5 A |
Rating | Catalog |
Special Features | Brushless DC Motor Control,Current-Limited,Diff Curr Sense Amp,Switching Control,Tachometer |
- DN-50 Simple Techniques for Isolating and Correcting Common Application ProblemsPDF, 130 Кб, Файл опубликован: 5 сен 1999
The UC3625 brushless DC-motor control IC incorporates many useful features that greatly simplify the design of low-cost and reliable brushless DC-motor drive systems. Although the controller IC is designed for ease of circuit implementation, a few precautions are necessary to insure proper operation. This design note discusses a few situations in which the IC may not operate correctly if suitable - U-130 Dedicated ICs Simplify Brushless DC Servo Amplifier DesignPDF, 420 Кб, Файл опубликован: 5 сен 1999
The UC3625 family of motor-controller ICs integrates most of the functions required for high-performance brushless DC motor control into one package. Brushless DC are commercially successful in high-end, four-quadrant servo systems, as well as in less demanding one- and two-quadrant requirements. Less expensive four-quadrant applications have not fared as well. Designs that meet cost goals often h - U-115 New Integrated Circuit Produces Robust, Noise Immune System for BrushlessPDF, 173 Кб, Файл опубликован: 5 сен 1999
The UC3625 family of motor controller ICs integrates most functions required for high-performance, brushless DC motor control into one package. With external power MOSFETs or Darlingtons, these ICs perform fixed-frequency PWM motor-control in either voltage or current mode while implementing closed-loop speed control and braking with smart noise rejection, safe direction reversal, and cross-conduc - U-120 A Simplified Approach to DC Motor Modeling for Dynamic Stability AnalysisPDF, 106 Кб, Файл опубликован: 5 сен 1999
When we say that an electric motor is a device that transforms electric power into mechanical power we say two things. First that the motor is ?and behaves as ?a transformer. Second that it stands at the dividing line between electrical and mechanical phenomena. In the case of permanent magnet motors this power transformation works in both directions so that the electrical impedance depends on
Серия: UC2625 (6)
- UC2625DW UC2625DWG4 UC2625DWTR UC2625N UC2625NG4 UC2625Q
- Semiconductors > Power Management > Power Management Special Functions > Motion/Motor Control
